Upcoming Projects
33 replies to this topic
#16 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted July 15, 2012 - 09:53 AM
Since I have a later model MF12 I plan to do video comparing the differences between them. I have found a few more.
I also found another '66 MF10 this is SN5100. I may use it for parts, it has an original HH100 in it. I may buy it for the motor for mine and put the HH120 on the MF12. The other MF10 also has a seat pan.
Edited by Amigatec, July 15, 2012 - 09:59 AM.
#17 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted July 15, 2012 - 10:52 AM
The plan right now is to rebuild my HH120 and put it back into the MF10, then I'll buy the other MF10 remove the original point type HH100, rebuild it, put it into my older MF10, and use the rest of the newer MF10 and my rebuild HH120 to restore the MF12.
Then I will use the MF10 for mowing and the MF12 for plowing.
I hope this makes sense??
Edited by Amigatec, July 15, 2012 - 10:53 AM.
#18 KC9KAS ONLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted July 15, 2012 - 11:02 AM
Good luck with all your projects.
I know how you feel about finding more tractors/goodies than you have $$ for!
I tell my wife that as long as I am working on the GT's, I'm not sittings in the bars, or chasing women!
#19 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted September 24, 2012 - 04:25 AM
I though I would update this thread.
Over the winter I have a few things to work on.
I need to pull the motor on the MF10, install a new set of rings, buy a new S/G nd reg for it, two tone the front wheels, and buy new belts for it.
I need to finish the rebuild on the Massey mower deck.
Now that I have an AU7 for my 5756 DB, I need to get it running, I am looking for a Contental gas tank for it, I need a pulley for it, and buy tires for it.
I have parts from a DB plow that I plan to turn into a hitch for the back of it. I plan to buy a trailer dolly from Harbor freight, and a metal seat from TSC, an turn those into a sulky for the DB. I will have to build a brake for it.
I also have the part from a DB sickle mower that mount to the front and plan to turn into a front dolly for my DB's.
Also if all goes well, I will be picking up a DB with a Wisconsin this weekend, it would be either a 112 or a 121 model, and a ground saw.
I still have to go get the TriTrac, but that may have to wait until next year.
Plus I plan to drag my CC149 around and finish it up.
I have a busy inter planned.
Edited by Amigatec, September 24, 2012 - 04:27 AM.
#20 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted September 24, 2012 - 07:10 AM
Sounds like you have a few things to do!
#21 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted September 24, 2012 - 08:52 AM
I bought the fuel tank this morning I was needing, and I have a line on the pully. Just need tires now.
#22 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted September 24, 2012 - 02:19 PM
Making a rider out of the walk behind would be an interesting thing to see, too.
#23 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted September 24, 2012 - 04:02 PM
Pat , I have a MF12H parts tractor, with most parts still there. The engine Tin had a number on I couldn't ID. Once I get home, late weds or Thurs morning I'll get the number if you'd help ID, I'd appreciate it and if you need any other parts, just let me know-Lee.
#24 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted September 24, 2012 - 07:23 PM
Post those #'s when you can, Lee. I'm sure someone will be able to ID it!
  • Toolpartzman said thank you
#25 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted September 24, 2012 - 07:39 PM
Well my projects may be on hold for a bit. I believe the transmission in my GMC Van is bad, it has a noise in it. I'm going o take it to the trans shop for a second opinion.
#26 KennyP ONLINE
  • 40,187 Thanks
  • 46,794 posts
Posted September 24, 2012 - 08:02 PM
That ain't good!
#27 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted September 24, 2012 - 08:06 PM
A noise could mean maybe just a drive shaft problem -hopefully--usally those GM trannys just quit shifting.
#28 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted September 25, 2012 - 03:13 AM
It has a rattle in it, it seems to only do It in low gear.
#29 mjodrey OFFLINE
Posted September 25, 2012 - 04:53 AM
Buy a Ford !!! :poke: :smilewink:
#30 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted September 25, 2012 - 06:04 AM
I would rather push a Chevy than drive a Ford.
Edited by Amigatec, September 25, 2012 - 06:05 AM.
