Jd 650..uh Oh?
10 replies to this topic
#1 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 06, 2012 - 09:01 PM
Ok found that I needed a new water pump and after ordering on, having a heck of time installing it and then putting it all back together I think I put the fan in backwards...Can anyone tell me for sure if the fan should be pushing air towards the radiator or pulling it away? Thanks for any help.
#2 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted July 06, 2012 - 09:10 PM
It should be pulling air thru.
  • middleageddeere said thank you
#3 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 06, 2012 - 09:12 PM
Really? SWEET! Thanks I thought I had to pull the whole thing apart again, I was sure it should be pushing air...Whew...Thanks
#4 MH81 OFFLINE
Posted July 06, 2012 - 09:39 PM
Flipping the fan over won't change it's direction of airflow. Only rotating the engine backwards would do that.
Glad you got the pump in, how's it running?
#5 olcowhand ONLINE
  • 40,313 Thanks
  • 31,161 posts
Posted July 06, 2012 - 09:44 PM
So how loose was the old pump once you got it off?
#6 JDBrian OFFLINE
  • 9,601 Thanks
Posted July 07, 2012 - 05:49 AM
Good to hear you got the 650 going again. Those are a strong tractor.
#7 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 07, 2012 - 06:41 AM
HAHAHAA!!! Glad I didn't screw up that bad! Sounds much quieter, I think the bracket for the alternator is rubbing a little and making a strange noise but other than that all seems well.
#8 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 07, 2012 - 06:43 AM
Ok so if you can imagine that the shaft should be at a perfect 90 to the body of the pump, the bearing was so loose that I could make that a 70 in any direction. I am pretty sure that the only reason it even stopped there was because the shaft itself was hitting. I will try to take a pic of it later today.
#9 MH81 OFFLINE
Posted July 07, 2012 - 06:49 AM
Glad the engine is rotating the right way. :p
A lot of fans can be mounted "flipped over", just make sure there isn't an offset that will allow the fan blades to hit or rub anything.
#10 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 07, 2012 - 06:50 AM
Yeah, when I first put it on I had that problem, luckily it was only the shield piece and I was able to rotate it without taking half the engine out again.
#11 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 07, 2012 - 07:16 AM
Anyone know what the appropriate size plow for this is?
