Simplicity Walk Behind Model V Transmission Seal
4 replies to this topic
#1 lawnmower bill OFFLINE
lawnmower bill
  • 2 posts
Posted July 05, 2012 - 09:42 PM
does anyone know where i can get a seal for the transmission?the part # is 8061118.it says non available every where ive looked.is there something else that will work?its letting oil run down in the gear box and i dont think it is supposed to have oil in it.only grease from a grease gun.can anyone shed some light on it
#2 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted July 06, 2012 - 04:55 AM
Have always used gear oil in the transmission.
The GA-54 and GA-118 seals were replaced by 8061118.
Can not find a change over but suspect if you remove the seal it can be matched up. Try Napa for a SKF/Chicago Rawhide replacement. The side of the seal may have another number on it depending who supplied it.
http://www2.chicago-...okup_457012.htm
Garry
  • lawnmower bill said thank you
#3 jbumgarner OFFLINE
jbumgarner
  • 72 Thanks
  • 109 posts
Posted July 06, 2012 - 06:49 AM
I would agree with tractorholic, unless the seal is destroyed you should be able to see the CR or national number. Then it shouldn't be a problem at all to match. Good Luck
#4 lawnmower bill OFFLINE
lawnmower bill
  • 2 posts
Posted July 08, 2012 - 03:22 PM
thanks guys,i tried napa but didnt have any luck.the guy worked 30 min trying to match something up. .it has allis 295g on the seal.ill figure something out and again thanks.
#5 DougT ONLINE
DougT
    Dog Approved
  • 6,855 Thanks
  • 4,953 posts
Posted July 08, 2012 - 07:06 PM
Try a bearing supply company. They can usually order seals by the I.D. and O.D. Sometimes they have better interchange too.
