Sears Mid-mount Grader Blade
11 replies to this topic
#1 Oo-v-oO ONLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted July 04, 2012 - 08:38 PM
Here's the mid-mount blade on my '69 Suburban in action. Pardon my grubby clothes, I was in work mode!
Since using it more, I have gotten better at using it. I've found that some extra weight on the back helps, too. Being able to use your feet to modulate the digging force is a huge help.
  • MH81, Alc, KennyP and 5 others have said thanks
#2 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted July 04, 2012 - 09:30 PM
Looks like it did a good job.I may have to fab one up for one of my old sears or the 145 ford.
  • tractorgarden said thank you
#3 MH81 OFFLINE
  • 29,979 Thanks
Posted July 04, 2012 - 10:01 PM
Lee, I saw a manual for one of those and have been pining for one ever since. Got a few things rounded up to make one, but don't have everything I want yet.
Little bit at a time, little bit at a time.
The bar that comes back, is there any "yaw" adjustment in that, or is that done with your feet?
#4 Oo-v-oO ONLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted July 04, 2012 - 10:41 PM
There are adjustments for angle left/right via the link I pointed out under the tractor at the beginning. You can have it straight across, left, or right.
There is also a threaded adjustment to tilt the blade to the left or right so you can make a crown on the road.
Finally, there is a threaded stop to give a fine adjustment for limiting the down travel. Additionally, the lift handle has stops similar to a mower deck height adjustment, so you can lift the blade up slightly and allow the dirt to roll off the bottom, to spread it out over a distance.
Very versatile attachment, for sure! I had to drive to NY State to pick it up, but I am glad I did. They came in two varieties, distinguished by the lift handle. Mine is the more rare and (I think) more functionally desirable one - it has a button coming out of the top of the lift handle you operate with your thumb to unlatch the lift. The other ones have a bent handle similar to the one used on the front dozer blades, where you would use your fingers to release the latch.
There are only 6 bolts that attach two brackets to the tractor frame. The brackets can stay and there is a quick-disconnect to drop the blade off if you want to use the mower deck.
#5 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 05, 2012 - 01:15 AM
I do believe that you have woody in your engine. I think you might want to let him out lol
#6 Oo-v-oO ONLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted July 05, 2012 - 04:54 AM
I think Woody will let himself out eventually! :smile1:
Yeah, she's tired. Keeps the mosquitoes down while it's running, at least.
#7 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 05, 2012 - 05:46 AM
I really like those belly blades...time to get/make one. Thanks for the video.
#8 Craig. OFFLINE
Craig.
    Ronald Craig
  • 1,196 Thanks
  • 945 posts
Posted March 12, 2013 - 12:29 PM
Ive been wanting to build one for my MF, to do my 200 ft. driveway. I'm thinking it would make crowning my driveway a lot eraser. Thanks for the underneath video shots, That will help me with the design of it.
#9 KennyP ONLINE
  • 41,000 Thanks
  • 47,160 posts
Posted March 12, 2013 - 05:35 PM
Good luck and take us along as you build it. I'm going to build one some day!
  • Craig. said thank you
#10 Oo-v-oO ONLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted March 16, 2013 - 09:54 AM
If you need more detailed shots, let me know. It won't be until the snow melts, though.
#11 farmerall OFFLINE
farmerall
  • 2,211 Thanks
  • 1,480 posts
Posted March 18, 2013 - 04:58 PM
Great video, that mid mount grader is a cool attachment and looks like it dies a good job.
  • Oo-v-oO said thank you
#12 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted March 30, 2013 - 06:54 AM
Oh boy, that is a great set up. I would be interested in some up close shots. I too have a long dirt drive that I maintain and am stock piling parts to make a grader. Thanks for the video and future pics. -Matthew
