Is It A Gilson?
13 replies to this topic
#1 DarryDoo OFFLINE
DarryDoo
  • 1 Thanks
  • 1 posts
Posted July 02, 2012 - 07:41 PM
Greetings, all. First time here.
I'd posted over on SSB Tractor about this particular tractor, and was told it looked like a Gilson. Here's the original post: (the attached picture is a composite, as I could only post one; if ppl want the originals posted, I can certainly oblige.)
Need some help identifying this old beast. There are no markings on the tractor or the engine. There's a part number 200376 on the "Operating Instructions" label, which is under the hood, but I found nothing relevant on Google.
I have no idea what the original colour is; the green is over red, which is over ?. *Everything* is painted red under the green body & black frame; maybe primer?
It has a true 4-forward-speed transaxle, which is belt-driven, I've never seen one quite like it. I think the transaxle might be partly seized, but I'm hesitant to disassemble without a manual of some sort.
No mower deck, but the plough blade was included. I originally thought it was home-brew, but the brackets where the assembly attached to the rear axle appear to be original. The box (bottom of the picture of the plough) was definitely added on, and contained weights. There are two locations for the lift arm, which leads me to believe it was meant for different models of similar tractors.
It's electric start, but there appears to be a spot on the top of the engine to add a rope starter; the "Operating Instructions" label says to remove the 25 amp fuse if there's no battery installed.
Anyone have any clues? I've looked at thousands of pictures on various websites, but nothing looked close. Thanks in advance!
  • middleageddeere said thank you
#2 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted July 02, 2012 - 07:44 PM
Wow, no idea but, welcome to GT talk!
  • DarryDoo said thank you
  • 14,730 Thanks
  • 15,470 posts
Posted July 02, 2012 - 08:43 PM
First off, Welcome to GTtalk ,glad you joined us. It appears to be a Gilson looking at the hood. If you could post the pictures separately, it would be better. Is the engine horizontal or vertical shaft? What HP is it? Gilson's were painted a redish orange in the later years of production.
#4 KennyP ONLINE
  • 37,526 Thanks
  • 45,524 posts
Posted July 02, 2012 - 08:59 PM
Welcome! I think separate pics would give folks a better shot at figuring it out for you! Someone will get you fixed up, sounds like TD&H is on the right track already!
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 02, 2012 - 09:14 PM
It's hard to tell, Like kenny said if the pictures were posted separately one could maybe get a better idea.
The shape of the steering wheel has me thinking Murray. I spent a lot of time on a gilson in the late 70's but don;t rememer the seat pan and fenders folding forward and can't quite see what the purpose would be.
Gilson like MTD and Murray would put anybody;s name and paint on a machine to suit if they would buy enough units to justify it.
Edited by JD DANNELS, July 02, 2012 - 09:17 PM.
#6 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted July 02, 2012 - 09:19 PM
Maybe it is a Murray/MTD with a Gilson hood on it. That noise/grill sure looks like a Gilson to me.
  • 14,730 Thanks
  • 15,470 posts
Posted July 02, 2012 - 09:35 PM
Here is a couple green Gilson's I found on the web..
#8 Sergeant OFFLINE
Sergeant
  • 46 Thanks
  • 136 posts
Posted July 03, 2012 - 05:54 PM
Looking at it it sure Looks Like a Gilson But I need to see some Bigger Pictures of the Lift Handle and engine compartment and a Better Picture of the Dash to Be 100% certain. But If It does Turn Out to Be a Gilson. Your Best bet is to Contact Toro. Outboard Motor(Lawn-Boy) Bought Gilson In 1989 and In 1990 They sold the Lawn-Boy Brand along with the Gilson rights to Toro :thumbs:
#9 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 03, 2012 - 06:05 PM
Its a gilson. No doubt about it. There is a distinct dip between the dash and the seat along with a long slot in the dash itself for what I think is either the PTO or the speed lever.
#10 catomann OFFLINE
catomann
  • 1 posts
Posted July 16, 2012 - 01:30 PM
Hah, yes it is. I bought an exact same model, mine is orange though. Got it yesterday, It is identical to yours. I am trying to use it as a lawn mower, it needs some love and care initally, but i am sure i can get the damn thing working again. Most of the mower parts are bent and have seen better days. Engine runs like a charm, all knives fell of one by one today, bolts snapped like matches. Better wear sturdy boots :)
Cato,
Loeten, Norway
#11 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted July 19, 2012 - 05:36 AM
looks like I am restating the obvious, but its a gilson/wards. somewhere around '78. I cant access my photobucket at work, so I cant post a bigger pic. The tractor in my avatar is a '77 gilson on steriods. I just joined yesterday and have not had time to upload any pics to my file. I will try to get some up this weekend
Edited by rat88, July 19, 2012 - 05:36 AM.
#12 EricFromPa OFFLINE
EricFromPa
  • 3,532 Thanks
  • 3,072 posts
Posted July 19, 2012 - 10:38 PM
:welcometogttalk:
#13 rcpicard ONLINE
rcpicard
  • 3 posts
Posted August 04, 2013 - 08:49 PM
check out this link. It may anwser your question.
http://www.americanl...k_16230449.html
Looks just like it, only red
#14 rcpicard OFFLINE
rcpicard
  • 3 posts
Posted August 04, 2013 - 08:54 PM
And here is a better one http://www.mytractor...d.php?p=1567325 this is a better pic. You will need to scroll down a little ways but you will see a nice pic.
