Db Sicklebar Parts
5 replies to this topic
#1 lost_in_samoa OFFLINE
lost_in_samoa
  • 1 posts
Posted July 01, 2012 - 11:46 PM
Hi All,
I am looking for a wobble bearing for a DB sicklebar model 917-5753.
Can anyone help?
Thanks
#2 Newpaws493 OFFLINE
Newpaws493
  • 1,368 Thanks
  • 1,811 posts
Posted July 02, 2012 - 01:03 AM
:welcometogttalk: I'm wondering if you meant to type Philadelphia in your location? :confuse: But anyways glad you joined up. There's bound to be someone here familiar with the parts you need,they'll likely stop by later in the morning. Site sponsors might be a source you could make contact with to start.
Good luck and pictures of your project wouldn't hurt... :camera:
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted July 02, 2012 - 03:28 AM
The bearing can be found at a lot of auto parts stores, I don't have the number handy, but it's commonly used as an axle bearing in a lot of cars. If you remove the bearing most parts stores can cross check it, cost is about $50.
#4 Alc ONLINE
  • 6,902 Thanks
  • 7,468 posts
Posted July 02, 2012 - 07:41 AM
Welcome to GTtalk , glad you joined , Al
#5 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 03, 2012 - 03:42 AM
Another thing you can try, is to carefully remove the seals from the bearing and clean it out. I did this to mine, I sprayed the bearing with carb cleaner to remove all the grease, then I took the bearing in the house and ran hot water threw the bearing to remove the rest of the grease and dirt from the bearing. Then I repacked the bearing and re installed the seal. As long as the bearing isn't badly pitted it should work fine. And I saved the $50 bucks.
#6 Cvans ONLINE
  • 6,662 Thanks
  • 6,134 posts
Posted July 03, 2012 - 08:43 AM
Welcome to the forum. Hope you are able to get your mower going again.
