Bolens Ride-A-Matic Finished Restoration
103 replies to this topic
#46 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted April 14, 2013 - 09:35 AM
I will get you some measurements and pictures. I'm glad it worked out for you.
BUMP
Anyone Have the lift link dimensions they could give me?
Also Would like some close ups and measurements of the Hi/Low range decal along with some of the Hood Decals
  • Bolens 1000 said thank you
#47 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted April 14, 2013 - 10:09 AM
Here is a pic of the entire hitch assembly. I had it handy on my phone so I thought I would post it. It sorta shows how it should look. I will get some better pictures. image.jpg
#48 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 28, 2013 - 03:46 PM
Here is a pic of the entire hitch assembly. I had it handy on my phone so I thought I would post it. It sorta shows how it should look. I will get some better pictures. attachicon.gifimage.jpg
After comparing... the 58' and 57' Had a few small variations in the rear hitches but the majority appears to be the same.
#49 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 28, 2013 - 03:48 PM
Anyone out there have a 57 Ride-a-Matic that they would be willing to take pics and measurements of the attachment lift bar so I can make one?
Cant start the resto until I get that rear hitch figured out.
Also It looks like the Triangle shaped piece of metal was hacked off mine so I will have to make one.
If anyone can get the dimensions of that piece I could appreciate it. Mainly Need the height (How far the piece sticks up and overall length of the Metal
(See pic below)
#50 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted April 28, 2013 - 04:06 PM
Pics of the Progress so far:
Out with the old:
OEM Parts Added :
#51 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 12, 2013 - 12:05 PM
(See pic below)
So no one has these dimensions?
Looks like I'm going to have to take a shot in the dark and fabricate the link the best I can ......
#52 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 14, 2013 - 04:31 PM
Decided to just go for it and use the pics available on the web and made up a Lift rod and fabricated the triangle shaped piece of steel on the back of the hitch.
I think things turned out pretty well with having nothing but pictures to go by.
Put the plow on and made sure everything worked as it should.
Now that I got things squared away with the hitch and lift bar I can now begin to dismantle the tractor for power washing then sandblasting then go through the engine.
#53 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 15, 2013 - 08:31 PM
Got alot of the chassis apart today
Found out the pulley on the engine was put back on without the key and set screws!! :wtf: I guess the previous owner must have used some sort of epoxy or adhesive product as that pulley was really stuck onto the shaft.
Took a little over an hour to get it off. Had to get the Kroil out then used the puller and lightly tapped the end with a hammer and moved it about 1/16'' at a time as whatever they used really adhered to the shaft and pulley. :wallbanging:
Still need to take apart the tranny.
Got the wheel hubs off but having never taken one of these apart before I figured I'd ask. Looking at the partslist it appears these inner hubs and pawls should just slide off right? there dosen't appear to be any set screws holding them in place.
Anyone ever had one of these rear ends out before?
#54 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5121 Thanks
  • 2911 posts
Posted June 16, 2013 - 02:34 PM
I never had one apart, Brian, but looking at the parts breakdown, it appears they may be held to the shaft with a roll pin (ref # 127).
It also appears that drive hub (ref #126) is keyed to the shaft with the woodruff key (ref # 116).
You'll probably have it apart before you read this. :smilewink:
#55 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 16, 2013 - 07:27 PM
Figured I'd wait and get some opinions before I broke something.
The roll pins that are in the assembly are pretty small and appear to be just there to hold that spring clip in place. They are small enough to make be believe they are not straight through the shaft as the primary thing holding them back.
#56 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted June 16, 2013 - 08:20 PM
The drive hub will just slide off, they are just keyed to the shaft. I had to use a puller to get them started though.
I had to replace a worn out pawl, but Bob's Garden Tractors had some.
Good luck with the resto.
Bob
  • Bolens 1000 and Bruce Dorsi have said thanks
#57 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 16, 2013 - 08:25 PM
Bob
Thanks!
It was hard to tell by the partslist and didnt want to start pulling not knowing what was back there .
#58 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 17, 2013 - 09:22 PM
The Hubs came right out with the help of a puller :thumbs:
Got the tranny out and removed the gears to get all the old grease out.
Everything has been power washed and is ready for sandblasting
Got the engine out and working on doing the valves rings, ect.
Will have pics tomorrow.
#59 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted June 19, 2013 - 08:27 AM
Here's some pics of the parts ready for blasting along with the custom paint I had matched.
The yellow came from a NOS mustang tiller Tine of the same era the Ride-a-matic was made.
  • Bruce Dorsi said thank you
#60 Bruce Dorsi ONLINE
Bruce Dorsi
  • 5121 Thanks
  • 2911 posts
Posted June 19, 2013 - 01:41 PM
The colors look good, Brian!  .....Is the green a metallic or a solid color?
I may be mistaken, but I think the green paint on Versas & most R-A-M's was metallic.
The earlier, slightly darker, green on PowerHo's & Gardeners was not metallic as far as I can remember.
Your paint supplier should be able to supply some fine aluminum powder/flakes to add to your paint, if needed.
