When Is It No Longer The Same Tractor?
48 replies to this topic
Poll: When Is It No Longer The Same Tractor? (21 member(s) have cast votes)
When does a tractor lose it's identity? What's OK to change?
  1. Only what has to be swapped (3 votes [14.29%])
    Percentage of vote: 14.29%
  2. Tin and Cosmetics (0 votes [0.00%])
    Percentage of vote: 0.00%
  3. Whatever's bad and you have a spare (14 votes [66.67%])
    Percentage of vote: 66.67%
  4. As long as you keep the serial tag. (4 votes [19.05%])
    Percentage of vote: 19.05%
Vote Guests cannot vote
#46 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 03, 2012 - 03:58 PM
Yeah, I didn't see one of the 4 answers that suited me. I like tractors that are either original or that are adapted to fit someone's needs or wants. I'm going for the latter.
#47 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted July 04, 2012 - 08:30 AM
As far as the Elec-Traks go , a stamped frame, traction motor , steering column / console and riveted sheet metal means you have an original. The correct color is to be followed for L nd G models and industrial models and also the OEM supplier. The chase for serial numbers sorted this out . Still some rooting to be done . Now for my own personal kick in the rear side . I am extremely allergic to certain yellow pigments .Small details :D Switching control relays out for new electronic controls does not offend most in the same way disc brakes are installed on vehicles made before they came out.
#48 MH81 OFFLINE
Posted July 04, 2012 - 08:38 AM
Thanks everybody, I appreciate the input.
I was concerned that changing to straighter tin and maybe the stronger tranny would be a loss of identity. Kind of the way Jennifer Grey isn't the same person after her nose job.
I need to figure out a good way to keep the serial tag intact without removal. Or if I do remove it, reattach it OEM rivet style.
No one will accuse me of being a rabid purist, but with it's unique story, I don't want to abandon it's history.
#49 Canawler OFFLINE
Canawler
  • 1,950 Thanks
  • 1,806 posts
Posted July 04, 2012 - 02:58 PM
I think the Chipster should stick to cars. Soooooo outside his realm, he wrecked the poor thing. :mad2: :toilethead:
I generally feel he also wrecks most of the cars he does.....
Your FrankenPanzer would be a PERFECT example for this thread. With a frame from one model of tractor and the body from another and an engine from neither, which tractor is it?....... :confuse:
Edited by Canawler, July 04, 2012 - 02:58 PM.
