1200 Creeper Drive
12 replies to this topic
#1 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted June 30, 2012 - 03:56 PM
we are in the process of restoring my sons first cub that he bought. in the process he came up with a creeper drive for it. i know on some of the drive shafts are marked, this one is not. i was hoping that one of you cub guys would be able to tell me how much i needed to cut off of it to make it the right. when we get her all back together i will post some complete pics.
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted June 30, 2012 - 09:15 PM
I believe its it is 4 3/4 inches but maybe somebody can come along and confirm or correct me.
  • powerstroker00 said thank you
#3 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted June 30, 2012 - 11:59 PM
thanks, i have looked everywhere and cant find anything. i still dont know why mine doesnt have a mark or a pre drilled spot for the roll pin.
#4 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted July 02, 2012 - 10:34 PM
I have a trans-axle sitting in my shed with a creeper on it, it still has the drive shaft in it. If I measured how far it sticks out would it help? I don't know what, or if there were any differences but mine came out of a narrow frame.
#5 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 03, 2012 - 12:29 AM
we got it figured out, with alittle help of a few buddy's. we borrowed a shaft that was marked and took it over for Grumpy to machine for us. got her home and installed today. its getting closer to being together, not happy with the paint on hood and side panels will probably wet sand and re-spray in the next couple of days and we have to do some patch work on the firewall.
#6 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 04, 2012 - 10:46 PM
100_2362.JPG 100_2436.JPG 100_2467.JPG 100_2474.JPG here are a few pics to tide you'all over. as soon as i figure out how to post a video,i will post the first start after overhaul.
#7 Jarvisih OFFLINE
Jarvisih
  • 9 Thanks
  • 27 posts
Posted July 05, 2012 - 10:11 AM
are you sprayimg wth a paint gun? single stage paint?
is that the briggs engine in your 1200?
#8 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 05, 2012 - 01:12 PM
ppg enamel paint. 12h kohler
#9 EricFromPa OFFLINE
EricFromPa
  • 3,527 Thanks
  • 3,071 posts
Posted July 18, 2012 - 03:18 PM
Hey that's looking really good.
Those rear fenders are a bugger to get perfectly straight aren't they.
My 127 was pretty straight but had the corners bent up from loose tire chains and my 149 well it's rear fenders are all kinked up from someone backing into trees and it had 150 lbs of weights hanging off of the rear hitch.
I'm working on getting them sorted.
I rolled the paint on my 127 with a small roller then sanded and cleared it.Turned out pretty darn good and the paint is on it really thick.My 149 is going to get sprayed once I get new hydraulic lines.One is seaping and one is cracked and leaking.
#10 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted July 19, 2012 - 11:21 AM
yes they are!!! we worked on them for several hours, but now you cant even tell i welded them. now if i can just get the hood sprayed like i want it, it will be done. i've sanded it back down twice now so hopefully 3rd times a charm. waiting for cooler weather to spray again. we have a show next wkend and my son says he's taking it with or without the hood.
#11 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted August 03, 2012 - 10:31 PM
100_0853.JPG 100_0854.JPG 100_0855.JPG 100_0841.JPG finally got the hood done!!!!and decals on just before the show. glad its complete,got alot of compliments at the last show. everything works great, motor sounds perfect and the newly installed creaper drive gives it all the power you need for whatever you want.here are some pictures at the show.
#12 Trav1s ONLINE
Trav1s
  • 3,183 Thanks
  • 4,292 posts
Posted August 05, 2012 - 07:29 AM
NIce Cub! My great uncle had one of those when I was a kid and I still remember sitting on it.
#13 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted August 05, 2012 - 02:11 PM
thanks, we had alot of compliments at the show last wkend and we took it to a show yesterday with the same results,
