John Deere 110
20 replies to this topic
#1 bolens1053 OFFLINE
bolens1053
  • 53 Thanks
  • 146 posts
Posted June 27, 2012 - 09:53 PM
HI everybody I am thinking about buying a jd 110 it is 100 it is pretty good condition it has an electric lift on it is that factory what do these usually go for? Is this a good deal?
Edited by bolens1053, June 27, 2012 - 10:25 PM.
  • 14,811 Thanks
  • 15,500 posts
Posted June 27, 2012 - 09:55 PM
Looks to be in pretty straight shape. The electric lift is a nice option to find, Very nice find.. Congrats!!
#3 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted June 27, 2012 - 10:44 PM
Yep the tractor is in great shape..... deck looks good and hood is not damaged. The headlight bezel also looks good and finding a ring and bulb should be fairly easy. This tractor does not have the original hood. It is a late flat fender tractor probably 1972. It has the inch front axle spindles and separate clutch and brake pedals and the manual pto lever on the dash instead of below the dash which make this tractor a very late flat fender. This tractor does not have the original hood. This tractor is a 112 and not a 110. Flat fender 112's were originally tecumseh 10 hp and later replaced by Kohler 10 hp . These engines were mounted directly to the frame. Finally JD fitted the 112 with a 12 hp K321A narrow base engine and put it on motor mounts. The flat fender tractors both 110 and 112 had the muffler mounted behind the grill. This tractor has the muffler mounted on the side of the tractor BECAUSE this 112 has the 12 HP K301 engine and the block was to big to allow for mounting the muffler between the grill and the engine. If you look at the serial tag you will see that you have a 112 and also if you look at the engine tag it will say K301A which is a 12 hp with narrow base. Also the only electric lift flat fender tractors that I know of were 112's and not 110's. And one more comment.... electric lift tractors said on the hood decal "112 electric lift"
You are looking at a late 112 with electric lift and 12 hp Kohler. Most of the electric lift 12 hp Kohler flat fenders had electric pto clutch also but this one has the manual clutch with the lever on the dash. This is a rare tractor !!!!!!
Also there was an optional spring assist on the front side of the electric lift.... a rare option if this tractor has it.
One thing missing is the mesh screen guard which shields the muffler.
If I were you I would grab that tractor !!!!!!!!!!!!!!!!!
Edited by MF14 plowday special, June 27, 2012 - 11:20 PM.
  • Alc, Texas Deere and Horse, bolens1053 and 2 others have said thanks
  • 14,811 Thanks
  • 15,500 posts
Posted June 27, 2012 - 11:10 PM
MF14, That is a lot of great info, thanks for sharing.. I have one and didn't all the things you listed.
#5 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted June 27, 2012 - 11:28 PM
I think MF14 plowday special is right.
I have both a JD 110 with hand lift for the deck, and my JD 112 has the electric lift.
Both tractors have the Kohler engines.
Notice the difference in the hood decals.
In the pic you can see the difference in the mufflers.
#6 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted June 27, 2012 - 11:29 PM
My JD 112 also has the 1 inch front spindles.
#7 Wheel Horse Kid OFFLINE
Wheel Horse Kid
    Certified Wheel Horse Nut
  • 213 Thanks
  • 817 posts
Posted June 28, 2012 - 06:48 AM
Great find! Sounds like a very good price to me. I am not a JD collector, but from what others have said it sounds like a fairly rare tractor.
#8 bolens1053 OFFLINE
bolens1053
  • 53 Thanks
  • 146 posts
Posted June 28, 2012 - 07:04 AM
Thank you for all that info that would be the reason why when i went to find what year it was none of the numbers matched because i was looking at 110 numbers
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 28, 2012 - 09:57 AM
For 100$ grab it! It's a great buy!
#10 daytime dave OFFLINE
  • 4,840 Thanks
  • 6,543 posts
Posted June 28, 2012 - 11:11 AM
Gosh yes, that is a good deal. I hope you go get it soon.
#11 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted June 28, 2012 - 02:49 PM
Here is an ebay parts tractor. Has 1 inch spindles and manual pto and "electric lift" on the decal and had separate brake pedal... these were a transitional tractor having some of the features of the soon to be 200 series which began production in 1974
25]Posted Image
#12 KennyP ONLINE
  • 38,384 Thanks
  • 45,933 posts
Posted June 28, 2012 - 06:54 PM
Dibs! I want the front axle!
#13 bolens1053 OFFLINE
bolens1053
  • 53 Thanks
  • 146 posts
Posted June 28, 2012 - 07:57 PM
well I looked at the serial number and it is 332069 but there is a decal above the stearing wheel and it says jd 110 variable speed?
#14 bolens1053 OFFLINE
bolens1053
  • 53 Thanks
  • 146 posts
Posted June 28, 2012 - 09:04 PM
I beleive it is a 110 because the serial number on the frame fit in with the 110 and the engine is a k241s I read on a jd website that in 1972 they offered an 8hp kohler and the 10 hp k241s kohler and in 1973 it was an option on the 110 to have electric lift here is a link
http://gardentractor...hnDeere110.html
#15 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted June 28, 2012 - 09:15 PM
I am going to say the you are looking at a 1974 110 going by the serial number. Yes electric lift was an available starting in 1973 for the 110. The reason they changed the mufflers to that style on the 110's and 112's is that when they went to the rubber mounted engines the exhaust pipe could not exit out the hood support because the it needed to be able to move with the engine.
Just a word of caution though make sure the electric lift works because if it does not it is very costly to fix.
Mark
