Vote for Tractor of the Month
Differences In K-series Kohler Blocks.
26 replies to this topic
#16 MF14 plowday special OFFLINE
  • 33 Thanks
  • 255 posts
Posted June 28, 2012 - 11:51 AM
Thanks, The PK block that I have on the outside looks just like the WH block. I was originally going to use the WH, because it also has a 1 1/8" crank for the pto. If I use the JD engine, I will either run a JD ele. clutch or machine a steel bushing to use the Ford clutch. This is a Second Generation LGT145, closed side panels with the rubber iso. motor mounts.
The bolt pattern for mounting pto clutches on 1 1/8 inch shafts is different than the pattern on Kohlers with one inch shaft.... so bushing up a inch shaft to 1 1/8 is not a viable solution.
PK had special order Kohlers made with a ring shaped boss cast into the block to mount the bell housing..... and I am wondering if that interferes with mounting an electric clutch??? On PK the electric clutches were on the flywheel side of the engine.
#17 Texas Deere and Horse OFFLINE
  • 14,466 Thanks
  • 15,392 posts
Posted June 28, 2012 - 12:04 PM
Thanks, I will look and see if the JD clutch will work on the Ford. If it will, I'll just use it.
#18 MF14 plowday special OFFLINE
  • 33 Thanks
  • 255 posts
Posted June 28, 2012 - 12:18 PM
Let me clarify.... a clutch made for 1 1/8 shaft can not be used on a a 1 inch shaft bushed up to 1 1/8 because the bolt pattern for mounting the clutch is different !!!!
#19 olcowhand ONLINE
  • 36,226 Thanks
  • 29,985 posts
Posted June 28, 2012 - 01:10 PM
Brian, older Cub Cadets such as the 107 had the Ford style block. Not sure on the Cub 1650 K341 though as I've never owned or been into one.
#20 KennyP ONLINE
  • 29,609 Thanks
  • 40,559 posts
Posted June 28, 2012 - 01:47 PM
The 1650 is a K301, 12HP according to the parts manual.
#21 Texas Deere and Horse OFFLINE
  • 14,466 Thanks
  • 15,392 posts
Posted June 28, 2012 - 02:36 PM
Kenny, The info at Tractordatacom says it's a K-341 AQS, and I also thought that the 1650 was a 16hp, 1250 was a 12hp.
#22 KennyP ONLINE
  • 29,609 Thanks
  • 40,559 posts
Posted June 28, 2012 - 04:47 PM
Apparently the manual is off. Don't know anything about these. But they do have a cradle the engine sits on, so most likely use the narrow pan.
#23 MF14 plowday special OFFLINE
  • 33 Thanks
  • 255 posts
Posted June 28, 2012 - 05:24 PM
AQS ..... the "A" is the designation for narrow base. The early JD 200 series had this type engine .... in fact I sold an K321AQS out of a JD 214 to a man who needed an engine for his CC 1450
The QS I think stands for quiet series. They have the irregular shaped air cleaner which receives air blown in from the flywheel
#24 skyrydr2 ONLINE
  • 3,540 Thanks
  • 3,237 posts
Posted June 29, 2012 - 07:40 AM
Talk about a can of worms... Wow! , all the different Kohlers and briggs i have, all have 2 diffent mounting patterns on them, the large rectangular one, and the smaller square one. , need to verify dims, but they are all the same. ??
#25 Trav1s ONLINE
Trav1s
    Got points?
  • 2,624 Thanks
  • 3,769 posts
Posted June 15, 2015 - 10:35 AM
Bring this back up as I am putting together a document with the Kohler build in my 312.  I am trying to spell out the differences in the various Kohler blocks.  Did we establish that there are 3 or 4 versions?
  1. Narrow
  2. Narrow with ears
  3. Wide
  4. Wide with ears???
#26 Trav1s ONLINE
Trav1s
    Got points?
  • 2,624 Thanks
  • 3,769 posts
Posted June 15, 2015 - 10:50 AM
From the K series manual
#27 KennyP ONLINE
  • 29,609 Thanks
  • 40,559 posts
Posted June 15, 2015 - 12:18 PM
  1. Narrow
  2. Narrow with ears
  3. Wide
You got me! Been a day or three since I read this thread!
  • Trav1s said thank you
