Hydraulic Plow For A Suburban
#1
OFFLINE
Posted June 27, 2012 - 07:40 PM
#2
OFFLINE
Posted June 28, 2012 - 07:17 AM
#3
OFFLINE
Posted June 29, 2012 - 01:54 PM
#4
OFFLINE
Posted June 29, 2012 - 08:48 PM
Hmmm, I have a pump off an old Massey Combine...
#5
OFFLINE
Posted June 30, 2012 - 02:05 AM
im not a hydraulic expert,but itd be pretty simple for the right person
i have an old valk plow,its lift is 12v,self contained,could easily lift anything a suburban would use
its all but 100 degrees here,ill bet plow parts are cheap right now!
#6
OFFLINE
Posted July 03, 2012 - 01:32 PM
EDIT:
I found it! I put it up on my website. It's in the "downloads" section, under the "misc. files" catagory. You will be prompted to create an account, this is mainly in place to keep people from putting viruses up and such.
Here's the link:
Hydraulic lift instructions for Sears Suburbans, GT's, and Customs.
Edited by BillTheTractorMan, July 03, 2012 - 01:59 PM.
#7
OFFLINE
Posted July 03, 2012 - 04:18 PM
Simple but effective. I wanted to keep the look of the tractor with out having a pump hanging off the side lol.
- MH81 said thank you
#8
OFFLINE
Posted July 03, 2012 - 05:33 PM
I have been thinking of doing the same thing to my ST16. What I would do is bolt the starter ring from an older techy and use it to spin a power steering pump. It would be well hidden in the frame of the tractor but I would still be able to work on it if needed. I would then cut 3 holes in the bottom of the dash for the valves then put a tank where the toolbox is. As for moving the attachments I would have quick connect couplers for the front, mid and rear attachments and when you wanted to tack an attachment off you just un hook it, disconnect the couplers and away you go.
Austin, I was thinking of doing the same thing on one with the bendix starter... I thought maybe I could tuck a small pump in the area where the S/G unit used to go and maybe use foot controls for the valves...
It's a pipe dream, I'll probably never get to it, but I was a-starin' the other day...
- Deck_Drive said thank you
#9
OFFLINE
Posted July 03, 2012 - 05:41 PM
I have the pump to do it I just havent fitted it yet lol. Money is ALWAYS in short supply.
#10
OFFLINE
Posted July 04, 2012 - 12:36 PM
#11
OFFLINE
Posted July 04, 2012 - 04:10 PM
DIRECT LINK
- olcowhand, powerking56, DougT and 3 others have said thanks
#12
OFFLINE
Posted July 04, 2012 - 04:29 PM
It sure is nice to find that kinda stuff here at GTtalk, and not need to go anywhere else.
- olcowhand said thank you
