Ok Just What Is This And What Is It Worth?
18 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 27, 2012 - 09:23 AM
Found this on Craiglist and am not sure what it is? They are listing it as an Allis Chalmers 515.
I could not find that model on Tractor Data, but found a listing for a 5015.
http://desmoines.cra...3068207156.html
#2 KennyP ONLINE
  • 40,903 Thanks
  • 47,102 posts
Posted June 27, 2012 - 09:38 AM
Looks like a well built tractor. And somewhere is a FEL for it, not sure if the owner has it.
  • JD DANNELS said thank you
#3 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted June 27, 2012 - 09:43 AM
I agree with Kenny, looks like a very strong machine. I would contact the owner and find out if he has the FEL for it.
#4 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted June 27, 2012 - 10:22 AM
Looks a lot like a Massey Ferguson 1010, just with AC logos. Daniel has a MF 1010
Edited by Chuck_050382, June 27, 2012 - 10:22 AM.
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 27, 2012 - 10:42 AM
Nice strong looking tractor. More of a compact tractor then a GT.
#6 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted June 27, 2012 - 10:48 AM
Is a good looking machine. I'd take it!
JDBrian, that brings me to ask (I'm new to this stuff) where is the line between GT and CUT?
#7 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted June 27, 2012 - 11:04 AM
That is a 5015. It's basically the same as a Massey 1010, but with a bit larger engine. The 1010 is 16hp, and the 5015 is 18hp. The hoods & grille are different, but everything else is pretty much identical.
  • MH81 and JD DANNELS have said thanks
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 27, 2012 - 11:07 AM
Chuck you may be onto something here. If it is a 5015 as I suspect, it spec's out just a shade higher than the 1010 with 18rated HP and 15 at the pto. Just a couple HP between and condition could easily wipe out the difference. And both are Toyosho built.
And Brian I agree, while listed as a GT, with standard category 1, 3 point and rear PTo it would fall into the SCUT/Compact area.
And TWOSTEP, there seems to be a Gray Area between the Bigger GT's & the Scut/Cut. Could be an interesting discussion there. For instance while most Scut/Cut's are liquid cooled Diesel, I would consider Daniel's AC 720 a Scut/Cut.
Edited by JD DANNELS, June 27, 2012 - 11:09 AM.
  • twostep said thank you
#9 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted June 27, 2012 - 01:05 PM
I'd make the distinction based on the 3-pt.
Cat 0 = GT
Cat 1 = SCUT/CUT
  • JD DANNELS, IamSherwood and KC9KAS have said thanks
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted June 27, 2012 - 01:31 PM
Cat 0 = GT
Cat 1 = SCUT/CUT
That is a good point of comparison, but I see some confusion in that the JD 700 series has what is called a Limited Category 1 hitch. Which I understand is Category one but limited in the height it will raise.
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 27, 2012 - 02:18 PM
That's what I found. Had one of those, or at least the previous generation, an x475 and the CAT1 limited hitch would take a standard 26"wide draw bar but only had a lift of about 10". There are a lot of attachments that are sized for scut's and they work just fine.
#12 MH81 OFFLINE
  • 29,978 Thanks
Posted June 27, 2012 - 06:12 PM
That's a beaut! 6 bolt rears AND fronts. Must be a massive GT or as pointed out above a SCUT.
#13 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted June 27, 2012 - 06:52 PM
Nice looking tractor, wouldn't mind have one.
#14 KC9KAS OFFLINE
KC9KAS
  • 5,466 Thanks
  • 4,722 posts
Posted June 27, 2012 - 07:38 PM
The catagory "0", "1" and so forth are based on tractor rated hp....I think I read this somewhere.
#15 IamSherwood OFFLINE
  • 8,395 Thanks
Posted June 27, 2012 - 07:40 PM
What would that thing weigh?
It's hard to put that in a class. What do the manufactureres consider to be GT/SCUT/CUT?
