Lgt14d Tach
7 replies to this topic
#1 twostep ONLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted June 26, 2012 - 03:03 PM
http://www.ebay.com/...=item35b97bc075
Anyone know how this tach works, as in mechanical or electrical? I want to add this type of tach/hour meter on my Kubota Z500.
  • 14,899 Thanks
  • 15,518 posts
Posted June 26, 2012 - 03:14 PM
I can't help you on this, but we had a discussion about tachs a few months ago. Here is the link to that thread, I hope it helps you out
http://gardentractor...page__hl__ tach
#3 olcowhand ONLINE
  • 43,152 Thanks
  • 32,007 posts
Posted June 26, 2012 - 03:18 PM
That's Bob's....member "bhts". He can answer your questions right here. Hopefully he'll chime in soon.
#4 bhts OFFLINE
bhts
  • 1,483 Thanks
  • 2,170 posts
Posted June 26, 2012 - 03:24 PM
That is a mechanical tach which uses a cable that runs from the tach to the motor.
#5 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted June 26, 2012 - 03:29 PM
Was just going to say that. It's from a GT14D diesel. With no spark to use as a trigger the diesel tachs are usually mechanical.
#6 Texas Deere and Horse ONLINE
  • 14,899 Thanks
  • 15,518 posts
Posted June 26, 2012 - 06:55 PM
Where do you mount it, to the injector pump??
#7 olcowhand ONLINE
  • 43,152 Thanks
  • 32,007 posts
Posted June 26, 2012 - 08:17 PM
I figured it was cable, but then some larger diesels can use a pickup coil sender on the flywheel or front pulley.
#8 twostep ONLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted June 27, 2012 - 08:08 AM
Thanks Bob, and thanks for the input from the rest of you. I'm looking for a tach/hour meter for my 2cyl Kubota diesel... an hour meter is no problem but the tach is not the easiest thing to do...
