wwhat happened cant get her to run now?
No, it runs... I was just having some fuel supply issues. I replaced the old fuel line though which helped. I think the carb still has some issues to work out of it as well due to age and I'm assuming if the engine was rebuilt at some point they didn't rebuild the carb at the same time, unfortunately. It will run for now though and I haven't had any issues with it not starting like it did to me that one time since I replaced the fuel line on it. The only problem I seem to still have is that it doesn't run that great in the cold until it warms up quite a bit, even with some choke on it. If you try to give it full throttle before it is warmed up, it bogs down and backfires through the exhaust (although it does spit some cool flames out when it does) and wants to stall out. Once it is warmed up though, it is fine. I also can't seem to run any PTO attachments until it is fully warmed up as that just kills the engine as well.
