145 Help...
30 replies to this topic
#16 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted June 26, 2012 - 01:05 PM
I also found this lying on top of the mower deck, what is it and where did it go? I found it before I started to disassemble the tractor. It's about 3" long, 2" wide, and has a 1" 90` bend on one end.
That's the lift bracket for the motor, should be bolted to the head over the shroud.
edit:
added picture
Edited by Chuck_050382, June 26, 2012 - 01:08 PM.
#17 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 26, 2012 - 01:11 PM
Kenny, it's the same as the 14HP. :thumbs:
Daniel, No, not still on vacation. It's just too hot to work on stuff that's not any fun. :laughingteeth:
Chuck, Thanks, thats why I couldn't find a lifting eye when I lifted the engine out of the frame, :confuse:
#18 KennyP ONLINE
  • 37,526 Thanks
  • 45,518 posts
Posted June 26, 2012 - 01:36 PM
Brian, I got my mounts from McMaster-Carr (I think), much cheaper.
Found them again:
http://www.mcmaster.com/#rubber-isolators/=i5c9tt
Edited by KennyP, June 26, 2012 - 01:43 PM.
Added Comment
#19 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 26, 2012 - 01:42 PM
That's what I thought I remembered, but wanted to ask again.You happy with how they work? Are they heavy enough?
#20 KennyP ONLINE
  • 37,526 Thanks
  • 45,518 posts
Posted June 26, 2012 - 01:47 PM
Doing a fine job that I can see! It says light duty, but just match mounting hole dimensions and ID.
#21 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 26, 2012 - 01:56 PM
Donor engine is almost out of the Horse...
#22 KennyP ONLINE
  • 37,526 Thanks
  • 45,518 posts
Posted June 26, 2012 - 04:43 PM
Cool! Gonna leave it red?
#23 MH81 OFFLINE
Posted June 26, 2012 - 04:59 PM
If he does, the tractor will look very patriotic...
#24 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 26, 2012 - 06:33 PM
Not leaving it red, Can't use the engine from the WH. I thought the block's were the same, but they are different were the pan bolts on. I will post some pictures in a little while. I think I have a JD block that should be the same, but will have to change out the crank.
#25 olcowhand ONLINE
  • 40,374 Thanks
  • 31,177 posts
Posted June 26, 2012 - 08:22 PM
I had meant to post that but forgot to. The block's bottom has angled notches just inside the oil pan flanges that the square Ford style pan won't cover up. Leaves a big gaping hole on both sides above the oil pan. I don't know why they put these notches in there, as the MF1650 Kohlers have the same type flanges, but do not have the notches, making them able to use either style oil pan.
  • Texas Deere and Horse and KennyP have said thanks
#26 Russ OFFLINE
Russ
  • 131 Thanks
  • 367 posts
Posted June 27, 2012 - 06:41 AM
Hey Kenny, Them hood hing are the same as the 195 ain't they ?? I would like to get one for each side if I could for my 195, I have one side that was broke before I got my 195 an beed looking for something to make em with but no luck yet, Let me know ok,, Thanks
#27 KennyP ONLINE
  • 37,526 Thanks
  • 45,518 posts
Posted June 27, 2012 - 07:40 AM
Yes they are, Russ!
Brian, sorry to hear the WH block won't work, but is good info for folks to know in their quest for parts.
#28 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 27, 2012 - 11:47 PM
Kenny, I started a thread on the differences in the K321 blocks. I hope get into a few more engine to find out the differences. It looks like the JD 214 block will work, and I have one that's complete, but not heard it run.
#29 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted June 27, 2012 - 11:48 PM
Hey Kenny, Them hood hing are the same as the 195 ain't they ?? I would like to get one for each side if I could for my 195, I have one side that was broke before I got my 195 an been looking for something to make em with but no luck yet, Let me know ok,, Thanks
Russ, I am going to be making a pair for mine, if they look and work well, I'm sure it won't be much trouble to build 2 sets.
  • KennyP and Russ have said thanks
#30 KennyP ONLINE
  • 37,526 Thanks
  • 45,518 posts
Posted June 28, 2012 - 05:01 AM
Saw that thread, Brian! I asked there if the JD would work, you answered here. LOL Hope you can fix Russ up. I'm just glad they are the same hinge!
