145 Help...
30 replies to this topic
#1 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2012 - 12:41 AM
The LGT145 I bought this weekend has a few issues with the tin work. The hood is mounted with a barn hinge screwed though the top of the hood and nose cone. I think there is supposed to be a set of hinges under the hood, not on top. If someone could take a few pictures of what the hinges look like, I might be able to fab a set. Also the back of the fender pan is beat up a lttle and I'm not sure how the shape is supposed to look. Thanks guys, I will post a few pictures of what I have in the morning.
#2 KennyP ONLINE
  • 41,024 Thanks
  • 47,165 posts
Posted June 26, 2012 - 05:31 AM
I'll see about getting some pics for you, Brian. I had noticed the hinge up there. Does it have the push button latch for the hood?
This is the parts breakdown for the hinges.
#3 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2012 - 09:17 AM
Kenny, It has a push button in the dash above the steering wheel, is that what you are talking about?
#4 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted June 26, 2012 - 09:20 AM
  • Texas Deere and Horse and KennyP have said thanks
#5 KennyP ONLINE
  • 41,024 Thanks
  • 47,165 posts
Yepper, that's it! Want me to take a hinge off and make a template to mail to you?
I see Chuck got you some pics!
#6 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted June 26, 2012 - 09:27 AM
I just happened to already have those pictures online from helping someone else out.
#7 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2012 - 10:25 AM
Kenny, A template would be great, if you have time. I can fab those up very easily. Thanks Guy !! :thumbs:
#8 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2012 - 10:42 AM
Here is a few photos of some of the tin work issues.
The hood hinge and sheet metal screws they used.
The rear deck pan
Rooted out foot rest,
Broken shifter cover plate,
hood release button,
#9 KennyP ONLINE
  • 41,024 Thanks
  • 47,165 posts
Posted June 26, 2012 - 10:57 AM
I'll see what I can get done this morning, plus a pic of the rear like your view. Somewhere around here I have my old plastic tunnel cover, maybe you can use pieces of it to fix yours. How's the dash? Mine needs help!
#10 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2012 - 11:03 AM
Thanks Kenny, I forgot to post that picture. One more thing to try to fix, LOL
Kenny, what is the pto shaft Dia. of the Ford's Kohler engine? And is it straight or tapered?
#11 KennyP ONLINE
  • 41,024 Thanks
  • 47,165 posts
Posted June 26, 2012 - 12:19 PM
Sent you a PM! It is a straight shaft, not sure of DIA. at the moment. Here's some pics of the rear and hinge:
Angle is about 30 degrees (or 60, depending how you look at it), flat across with a slight bend up at the bottom.
#12 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2012 - 12:39 PM
Thanks So Much Kenny, I have pulled the engine out of the frame and have another K321 out of a Horse to drop in. Both have 1 1/8" straight PTO shafts, only looks like I will have to change the oil pan. Later when I get the chance, I will rebuild this one and put in on something else..
This engine is very oily and dirty, worried about how well it has been cooling.
I also see that I need new rubber engine mounts, Are they available thru Ford ?
#13 Texas Deere and Horse ONLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 26, 2012 - 12:46 PM
I also found this lying on top of the mower deck, what is it and where did it go? I found it before I started to disassemble the tractor. It's about 3" long, 2" wide, and has a 1" 90` bend on one end.
#14 KennyP ONLINE
  • 41,024 Thanks
  • 47,165 posts
Posted June 26, 2012 - 01:00 PM
Found the spec on the crank for my 165:
PTO end should be the same on the 14HP, I hope!
#15 olcowhand ONLINE
  • 42,901 Thanks
  • 31,943 posts
Posted June 26, 2012 - 01:02 PM
Brian, you must still be on vacation with all you're getting done??????
