Paint Gun And System
11 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted June 25, 2012 - 11:07 AM
Any of you familiar with these systems and guns?? What is a used on worth??
What is the up side to this type of system??
Thanks
#2 KennyP ONLINE
  • 40,975 Thanks
  • 47,147 posts
Posted June 25, 2012 - 03:29 PM
Never saw one before. What's the box for?
#3 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted June 25, 2012 - 03:58 PM
I think this is a all in one unit
Hoping maybe Josh will recognize it
They were talking about an electric sprayer and I found this one for sale where I travel. I think this is what this is.
#4 Byron R OFFLINE
Byron R
  • 57 Thanks
  • 120 posts
Posted June 25, 2012 - 05:50 PM
Sacsr..that's a HVLP...(high volume low pressure) ..Unit ..I've owned a hvlp for about 10 yrs.I've sprayed 4-5 fullsize tractors...lots of stain and poly(woodworking)..and a couple hit-miss engines..Not much over spray..I'm sure that appolo is a much better system than the one i own mine is a cambell housefield..Got to watch if the gun has not been cleaned out right..
  • sacsr said thank you
#5 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted June 25, 2012 - 06:44 PM
Those are expensive units! $800 on ebay. One upside over a shop compressor is there is likely no air tank involved to build up moisture, and likely oil-less also. Much cleaner/drier air for painting.
#6 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted June 25, 2012 - 06:56 PM
Air gun is supposedly new
Wants $350 for it
#7 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted June 25, 2012 - 06:57 PM
Anything to look for to go wrong with them?
#8 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted June 25, 2012 - 07:26 PM
I really don't know anything about the system, but I would want to run the compressor a good 15 minutes to 1/2 an hour before I would be willing to buy it. If the motor or compressor have issues, that's long enough for them to show up. The gun will be fine if it's been cleaned right.
#9 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 25, 2012 - 07:36 PM
These are great systems for general painting. The gun is what makes the difference in the quality of your paint job, along with prep and other things. We used to have one a few years ago and I loves painting with it, but all I painted was our finished work. Scott, I would try it and you can always sell it to someone if you don't like it. Good Luck..
#10 Byron R OFFLINE
Byron R
  • 57 Thanks
  • 120 posts
Posted June 25, 2012 - 08:11 PM
If the gun has not been cleaned right ...between uses it could be worse than any bomb/spray can you ever used..I loaned my sprayer out to a buddy..that did not clean it as good as needed..said he did,,but that was not the deal...It took lots of acetone and scrubbing to get the sprayer cleaned back -up..i'l never loan it again..I gave close to $400 for mine 10 years ago..HF has one listed ..for about a hundread...they can be dialed from almost airbrush to flat laying it on..
#11 MH81 OFFLINE
  • 29,979 Thanks
Posted June 25, 2012 - 09:00 PM
You might better check with the local police and see if someone had one less than they remember.
No one gives stuff away if they know what it's worth... Approaching " to good to be true" status here.
#12 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted June 26, 2012 - 11:10 AM
Those are almost like a Vacuum motor with big air volume. Eastwood used to push them pretty hard years ago, and still have some refined systems avail. Their guns used to take the big hose all the way to gun and looked bulky to use I thought. Newer ones have smaller hoses. As noted High Volume, Low Pressure and not much overspray. Have never seen one or it's finish cept in the Eastwood books they show them using it on their project rods. makes a bigger softer band of paint while applying looks like.
