1968 Jd 140
85 replies to this topic
#61 hdg4400 OFFLINE
hdg4400
  • 284 Thanks
  • 348 posts
Posted May 27, 2014 - 08:36 AM
ckjakline:
As many have said, Looking Good!  I had a 140 H1 for about 20 years and loved it. I worked it pretty hard, and finally replaced it with a 318 fall of 2011.
I looked through your entire thread this morning and noticed the bolts on the battery pan. I wonder if they should be shorter to lessen the chance of damaging the battery. Though clamping the battery in should help prevent that. Just wondering.
Harlan
  • ckjakline said thank you
#62 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted May 27, 2014 - 03:35 PM
Harlan
Yes they do need to be shorter.I need to get shorter bolt for the battery tray.I just used what I had at the time.Thanks for reminding me I forgot about changing them.
#63 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted August 08, 2014 - 09:04 PM
I actually worked on my 140 tonight.I've been working 60 to 72 hours a week for the last 2 years and don't get a lot of free time anymore.I actually have my first sat off tommorrow since fathers day weekend.2 weekends ago I wire wheeled the seet pan and primered it.The seat pan had some pitting so I did three coats of primer then sanded just the back of the pan that will be exposed after mounted.Primed the back again and went heavy over the pitting.Sanded and reprimed and it was to my liking.Last weekend I then gave it 2 coats of green where the seat cushion sits.Flipped it over and did the bottom and back 2 coats.Wet sanded,another coat of green,wednesday I wet sanded again and gave it the final coat.I brought it home tonight and installed my new Hapco high back seat cushion.I then mounted seat on the tractor,and it looks great.
Then I also mounted the rectifier regulator,the fuel tank,and the coil.I mounted and set the governor,and put the throttle cable in place,but need to get the hardware for the lever.
  • Texas Deere and Horse, johndeereelfman, Trav1s and 2 others have said thanks
#64 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted September 09, 2014 - 08:13 PM
On sunday I got the throttle and choke cables fastened to the dash and onto the carb.Started wiring tractor,and installed solenoid.Tonight I cleaned up and installed the cigarette lighter,cleaned up the pto switch,and ran the hot wire from amp gauge to solenoid.Both the cigarette lighter and pto switch I used steel wool to clean and polish them.The chrome on the lighter really cleaned up nice.The switch cleaned up but is still dull.Although it is a cast alum housing I didn't want to paint it.I'll try and take pictures tomorrow night.
  • johndeereelfman and Trav1s have said thanks
#65 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted September 10, 2014 - 08:01 PM
Worked on the wiring again tonight.I ran the wire for the electric pto,and hooked up 3 wires to the pto switch.Just have to go from pto switch to neutral safety switch and that'll be done.I'm getting there slowly.Hope to have it pretty well finished by the end of sept.We'll see.
#66 Texas Deere and Horse OFFLINE
  • 14,814 Thanks
  • 15,501 posts
Posted September 10, 2014 - 09:33 PM
Man, It sure is looking sharp, can't wait to see you driving it around showing it off. Very nice job!!
  • Trav1s and ckjakline have said thanks
#67 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,366 posts
Posted September 21, 2014 - 06:36 PM
Got any more pics of the work?  The area under the hood looks much different in green than in blitz black like my 120.  I am taking notes for my '68 110.
#68 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted September 23, 2014 - 05:24 PM
I'll have to take more.I just have to run the wires for the lights and the wiring will be complete.Was there anything in particular you wanted to see more shots of?
  • Trav1s said thank you
#69 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,366 posts
Posted September 23, 2014 - 05:39 PM
Just admiring the work because I know what is involved in a project.  :smilewink:
#70 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted September 28, 2014 - 08:32 PM
I finished the wiring this week.Yesterday I got the starter primed and painted.I was going to bolt it on tonight but the bolts I had weren't long enough.I'll try and get some this week some time.I need to get battery cables yet and I will be able to see if it starts.I mounted the hood supports tonight and put air filter pre cleaner on and set cover in place.I need to get a 1/4-20 wing nut for it yet.I also got the muffler in place and fastened.Here are the lastest pictures.
Edited by ckjakline, September 28, 2014 - 08:35 PM.
#71 Cat385B ONLINE
    HAZMAT CAT
  • 13,979 Thanks
  • 10,006 posts
Posted September 28, 2014 - 09:54 PM
Is the muffler new, or coated?
#72 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,366 posts
Posted September 28, 2014 - 11:10 PM
Looks like JD muffler black to me.
#73 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted September 29, 2014 - 03:11 AM
It's the original muffler that was on tractor when I got it.I sandblasted it and gave it a coat of high temp Rustoleum black.
  • Cat385B said thank you
#74 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,366 posts
Posted October 01, 2014 - 12:21 PM
Thanks for the pics.  The work looks great and I can't wait to see the end product.
#75 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted October 13, 2014 - 04:40 PM
The other weekend I was at the steam-o-rama in Windsor,Pa and found a very straight and damage free grill.I bought it, brought it home,sanded,primed and painted the grill..I have a couple grills but all were damaged and torn screen.The following day I was at a local Mack truck show,and found some L.E.D lights for $3 a pc.I bought 2 not knowing if they would work.Turns out they are pretty close to what I needed.I should've bought more.They would've worked on my Massey  14 and 16 also.I got them mounted and just have to hook up the ground yet.Here are some updated pictures.
