Starter
starter drive
8 replies to this topic
#1 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted June 23, 2012 - 11:37 PM
during this moving some one else has jumped own it and it has failed to start, So now I have the starter off and it appears that the Starter Drive has give up. An Help would be Appreciated, it will be the first one I've took down.
  • 14,901 Thanks
  • 15,518 posts
Posted June 23, 2012 - 11:39 PM
Dale, What gt and engine is the starter on?
  • dstaggs said thank you
#3 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted June 24, 2012 - 05:31 AM
If you mean the starter won't engage the flywheel that is a fairly common problem and most often can be remedied with a good cleaning and some lubrication. As said above more info. would help.
#4 dstaggs OFFLINE
dstaggs
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted June 24, 2012 - 06:51 AM
Sorry No Brain!!!!! It is a Cub Cadet 3206 20hp Kohler V Twin. It will have to wait for a few days got to go pull 2-300 ears of Sweet corn.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted June 24, 2012 - 07:45 AM
Dale, does the starter go, but not engage? If so, pull the tin and starter and check the teeth on the little gear. If they look OK, check the teeth on the flywheel.
If all above ok, it's probably the bendix needing cleaned and lite oil lubed. My experience is that silicon spray is good, white lithium is bad. Every speck of dirt in three counties stuck to that lithium and had to do it again in short order.
#6 MH81 OFFLINE
  • 29,979 Thanks
Forgot to add, just lube the barber pole, not the gear itself.
#7 dstaggs OFFLINE
dstaggs
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted June 25, 2012 - 08:18 PM
Hot Diggit Dog followed Alan's words of Wisdom and now it is back on and Starting Again. Thanks
Edited by dstaggs, June 25, 2012 - 08:19 PM.
#8 Texas Deere and Horse ONLINE
  • 14,901 Thanks
  • 15,518 posts
Posted June 25, 2012 - 08:33 PM
Way to Go Dale, Glad your up and running. :thumbs:
#9 dstaggs OFFLINE
dstaggs
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted June 25, 2012 - 09:34 PM
Now if we could get some RAIN maybe the Grass will grow.At least I'm back in the saddle again. The temperature was 107 this afternoon.
