Edited by 8tyman8, June 22, 2012 - 04:48 PM.
Posted June 22, 2012 - 04:46 PM
Posted June 22, 2012 - 05:33 PM
Posted June 22, 2012 - 07:33 PM
Posted June 22, 2012 - 11:56 PM
well its june and i a bought a berco 40" blower for $100 there worth $800 + and this one has almost no use its a close fit for the tube frame i even have a right angle gear box thats new the mounts are 1/4 off on each side so a bracket like on the large frames will be needed to make it work should be a good build it will also get hydraulic movements up- down chute left-right up-down
Posted June 23, 2012 - 02:20 AM
Posted June 23, 2012 - 06:51 AM
yep the pictures were taken on different days the first with the hood open is my 1256 and the second is my h14 thats been re-powered (the blower will on the h14) the hood is modified so its 1" forward at the bottom and 1 1/2 at the topNice looking blower!!!
I think I see two different tractors in the attachments--one has a vertical stack and one has the muffler along the side.
U.S.
Posted July 04, 2012 - 01:13 AM
Tyler
Edited by 8tyman8, July 04, 2012 - 07:56 PM.
Posted September 20, 2012 - 08:07 PM
Posted September 21, 2012 - 10:11 PM
Edited by 8tyman8, September 22, 2012 - 11:02 AM.
Posted October 19, 2012 - 04:16 PM
Posted October 19, 2012 - 08:47 PM
I had one for my JD 165 WAY to much blower for the tractor i could not go any where with that thing was always getting stuck or spinning i even had 2 link chains still spun it also bogged the engine down it was a big mistake trading a running working sx75 for .... i miss that Lil mowerThis will make a great build. It looks very similar to my Haban single stage on the Sears SS12, weight wise. It is a lot of blower for the tractor, but not too much. I did have to add more weight to make reverse work right again. Kept spinning when lifting and backing up.
Posted December 25, 2012 - 04:59 PM
got it out and Going it worked well i do need to get shear pins tho
Posted December 25, 2012 - 08:07 PM
must say nice job on the blower now you neeed to build a cozy cab, it gets cold up in canada
Edited by 1967bolens collector, December 25, 2012 - 08:08 PM.
Posted December 25, 2012 - 08:24 PM
I found a Soft cab that i plan to buy if not i have a Jd cab i will mod to work
