My 1650a has become rather sluggish going uphill and slow to catch up after going down hill. Im going to give the cooling fins a cood cleaning and check on the cooling fan, but I think it might be time for a fluid change as I have never performed one since owning it. What fluid do I use in the transaxle? What's everyone using in their Kohlers?
Hydro Fluid For My 1650a?
Started by
Buzzard217
, Jun 22, 2012 09:32 AM
3 replies to this topic
#1
OFFLINE
Posted June 22, 2012 - 09:32 AM
#2
OFFLINE
Posted June 22, 2012 - 10:03 AM
The last page of this manual has your info.
http://gardentractor...del-11-service/
I use Tractor Hydraulic oil in my Eaton and Sundstrand hydros with no issuses. Bedouble sure you get and correct filter
#3
OFFLINE
Posted June 22, 2012 - 10:15 AM
I'm not that familiar with the linkage in those tractors but have you checked out and lubed the linkage. There is sometimes a damper in there that slows down the response to the pedal input. If that's leaking or broken it will cause some funny things to happen to the way the hydro responds.
#4
OFFLINE
Posted June 22, 2012 - 11:31 AM
Did some checking on the filter requirements for the Eaton and it requires 10 micro and 4.5 gpm minimum flow.
The wix 51702 of Fleetgard HF 6446 will meet that spec.
