Ariens 831005/831006 34" Tiller
5 replies to this topic
#1 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted June 21, 2012 - 12:01 AM
The 30 tooth output gear is NLA for the gear box.
The 15 tooth input gear is avalible.
What, migh I ask, is a person to do?
My thoughs were;
#1 to find a set of 2:1 Bevel gears that would fit, not happening.
cant find a set with a 3/4" bore and a 1-3/4" mounting distance
#2 buy a 1.5:1 set for a John Deere 33 tiller, hoping the input and output shafts are the same length, and change the 5" OD driven pulley on the input shaft to a 7-1/2" driven pulley.
Bill
#2 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted June 21, 2012 - 06:50 AM
But there is no 2AK 7-1/2" pulley available, only a 7-1/4" 2AK74x3/4.
So beings I was going to make a pulley for the PTO shaft with a 2AK34x1 3.45" that should be here today, the closest I could find to the 3-1/2" ones my dad made, and the 1"-15 splined coupler I got from the Surplus Center http://www.surplusce...sp?item=1-1561.
I guess I'll need to buy a 2AK32x1 3-1/4" pulley or live with the faster tine speed?
:anyone:
#3 MH81 OFFLINE
Posted June 21, 2012 - 07:11 AM
Where all have you looked? There's a place here in PA called Erie bearing that is pretty good about getting oddball stuff.
Good luck!
#4 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted June 22, 2012 - 10:02 AM
I searched Doge and Martin's gear catalogs.
Side note
Part #11 shown here
Ariens 03144600 BEARING GUARD CAP
John Deere CAP M41209
What are they called and where can I buy some?
Edited by Wm McNett, June 22, 2012 - 10:05 AM.
#5 shorty ONLINE
shorty
  • 5,468 Thanks
  • 5,257 posts
Posted June 22, 2012 - 05:55 PM
For the bearing cap, that looks like a part that wouldn't be found elsewhere. My guess would be to check with someone who parts out tractors. Same with the gears. It can be so frustrating when one can't find parts you want. Why can't the factories use standard parts off the shelf instead of customizing every gear. Sorry I don't have good info for you.
#6 Wm McNett OFFLINE
Wm McNett
  • 126 Thanks
  • 169 posts
Posted June 22, 2012 - 11:24 PM
Searching for lower chain case/tine shaft bearings?
1-1/4" ID, 62mm OD, Wide Inner Race, Eccentric Collar, Non-Relubricatable
Fafnir/Timken 1103KRRB3
Federal-Mogul/BCA/National WPS103GP2C
HS5125
No one wants to pay Ariens $80+ each price
