Plastic "gizmo" Drain Plug On 22hp Kohler Command ?
#1
OFFLINE
Posted June 20, 2012 - 09:10 PM
#2
ONLINE
Posted June 20, 2012 - 09:52 PM
#3
ONLINE
Posted June 20, 2012 - 10:42 PM
I do think the add-on hose idea is daft, just put the drain where it won't pour all over the steering linkage to start with, and you don't need that POS hose that I lost in a week...
#4
OFFLINE
Posted June 21, 2012 - 03:03 AM
- MH81 and jpackard56 have said thanks
#5
ONLINE
Posted June 21, 2012 - 05:04 AM
#6
OFFLINE
Posted June 21, 2012 - 02:10 PM
Yep, its on a Cub and when I went to turn the yellow PLASTIC cover piece it flew of the end exposing a couple o rings. I was not being rough with it. If this is what a couple of the other fellas have had good luck with them I'm guessing the manufacturers have cheapened them up a bunch !!! Today I measured for a nipple and plug. When I went to remove the base part of the plastic "gizmo" it was not threaded tight either, just turned out by hand. I need this thing to work, so I'm glad I found out before I had to jack around with a warranty claim. Thanks for the feedback.You don't say whether this is a cub or not, If it is or a husgavarna make sure it is tight were it screws into the block, then when out of warranty get rid of it and put a long nipple with a cap on. Kohler bought alot of engines under warranty because of those plastic nipples coming apart,
#7
ONLINE
Posted June 21, 2012 - 03:58 PM
- jpackard56 said thank you
#8
ONLINE
Posted June 23, 2012 - 02:10 AM
Sorry you're underwhelmed by the construction, hard to get used to the new junk when were all used to playing with well built stuff from 30 yrs ago.
#9
OFFLINE
Posted June 23, 2012 - 06:29 AM
I see one of the fellas said his grille had sagged from engine heat...
I haven't got my brothers in-fared reader yet (should see him over the 4th) I still plan to check temps before and after adding the cooler. I know we have better engineering and technology than this... but obviously the new way is all about "just in time and just enough to get out of warranty"
#10
OFFLINE
Posted June 23, 2012 - 06:38 AM
#11
ONLINE
Posted June 23, 2012 - 10:39 AM
Hope you get this problem resolved.
