I did a little horse trading and part of the deal was a Mantis tiller with a "dirty carb"
They were right... And a ripped fuel pump. I did the old gasket trick to work around that just to get it running, but after about 6' of tilling, it just stopped. I though my gasket had gone bad, but I was getting fuel, no spark. It's an echo (Kioritz) sv-2ae engine.
Part number 138 on page 3 here: http://mantis.com/gl...02_pn_385_3.pdf
Kind of narrowed it down to an NLA part, the coil. They have them on epay for $50, but before I dump money into this, I thought I'd like to try it and see if it was going to work right. Also, am a little suspect that the guy really has 200 of these things...
Now the question, anyone know of a work around? Permanent or otherwise?
There is only 2 wires going into it, so I was wondering if a regular coil could be made to work somehow.
3 replies to this topic
#1
OFFLINE
Posted June 20, 2012 - 06:36 PM
#2
OFFLINE
Posted June 21, 2012 - 01:28 AM
I read on another post "sorry cant remember where"that someone tried that and fried the coil. Something about auto coils putting out 12v then dropping to 7 or 8v. and small engine coils putting out 12v all the time. Maybe it was in the bolens forum?
- MH81 said thank you
#3
OFFLINE
Posted July 04, 2012 - 08:56 AM
Here is a link to a similar type conversion...http://www.simpletractors.com/do_it/magneto_to_coil.htm
I did this on a tractor and it worked great.
I think you should be fine.
#4
OFFLINE
Posted July 04, 2012 - 09:11 AM
Unfortunately, this doesn't have a set of points. I am trying to swap the flywheel with something standardized off a weedwhacker and adding an external mag. So far, I got it to backfire LOUD, so I was getting spark, just had the timing wrong.
Kids soccer has started, so my free time is much less than it was 2 weeks ago. Project shelved until my hearing returns and soccer is over
- middleageddeere said thank you
