1220 Repower Question
17 replies to this topic
#16 Jack OFFLINE
Jack
  • 1388 Thanks
  • 891 posts
Posted August 28, 2012 - 06:43 PM
You might want to check this out. This fellow can show you how to use some car parts and make a new ignition system. There are several different people doing this. You just need to do a bit of research. Good luck.
Jack
http://home.earthlin...ller/index.html
Edited by Jack, August 28, 2012 - 06:45 PM.
#17 brianintheup OFFLINE
brianintheup
  • 3 Thanks
  • 20 posts
Posted August 28, 2012 - 09:32 PM
Ya, I looked at his information. I was able to get the v-twin for free. So that's why I am going that rout. I'll post some picts of the project.
#18 brianintheup OFFLINE
brianintheup
  • 3 Thanks
  • 20 posts
Posted August 29, 2012 - 04:30 PM
I got both engines out sitting side by side. The briggs and the pulley from the hh120 are going to the machine shop in a day or two so the two can be fitted together. The base of the briggs is bigger and wider than that of the hh120 so I am making a plate to mount to the tube frame and then the briggs will mount to the plate.
