John Deere 160 Manual
56 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 20, 2012 - 03:01 PM
Does anyone have a service and owners manual for a 160 that they could email me thank you
  • larisaPn and dwaynerj11 have said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 20, 2012 - 06:49 PM
I may be able to help. The file is large almost 20mb. Will your email account take a file that large? If so then send me a personal message with your email address.
  • ace69xxx2000 said thank you
#3 hdg4400 ONLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted June 20, 2012 - 08:30 PM
I don't know which manuals JDBrian has, but in case it doesn't include the Operator's Manual, I have it. It is titled "130, 160, 165, 175, 180, and 185 Lawn Tractors" OM-M72257, and is labeled "Dealer Service Shop Copy".
Based on a similar manual I just scanned in, the PDF for this one should be about 8 or 9M. If you're interested, let me know. It might be a few days before I can get it scanned.
Harlan
Edited by hdg4400, June 20, 2012 - 08:31 PM.
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 21, 2012 - 05:53 PM
Email sent!
#5 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 22, 2012 - 05:37 AM
Thanks Brian that is a huge help
#6 Diesel Dave OFFLINE
Diesel Dave
  • 3 posts
Posted July 15, 2012 - 08:12 AM
I just got 160 last weekend would really like to get the manuals too if possible.
#7 hdg4400 ONLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted July 15, 2012 - 02:14 PM
Dave: I sent you a Private Message with the Operator's Guide attached. Hopefully JDBrian can get you other manuals. Good Luck!
Harlan
#8 bigruss OFFLINE
bigruss
  • 1 posts
Posted July 02, 2013 - 02:34 PM
Can someone also send me the 160 sevice manual? It would be a huge help.
thanks
Russ
#9 ronthomp OFFLINE
ronthomp
  • 3 posts
Posted August 17, 2013 - 07:41 PM
Hi, I am a new owner of an older 185. I am having trouble with the belts on the 46" deck.
I'd love a copy of any manuals anyone may have.
Thanks!
#10 hdg4400 ONLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted August 17, 2013 - 09:55 PM
ronthomp:
I sent you a Private Message with some info that may help.
Harlan
  • ronthomp said thank you
#11 ronthomp OFFLINE
ronthomp
  • 3 posts
Posted August 18, 2013 - 09:03 AM
Thanks!
This is the manual I was looking for. I see there must be different versions, as the deck springs are different on mine.
My 46" deck has a tension release lever for the belt that goes from the pto to the deck. And the belt that goes around the spindle pulleys has an idler spring that goes to a welded hook on the fore part of the deck. This spring seems to be non-standard and way oversized. There is a piece of scrap steel between the spring and the hook. I suspect there should be a turn buckle there or at least a weaker spring with a longer travel.
Also, my lifting mechanism no longer works, and appears to be missing parts. One bar is broken and the lift assist spring is missing. And, the thumb button stays down.
It was mowing well with the deck riding on the scalp wheels, but the new kevlar spindle belt has stretched enough that it won't drive.
Today I intend to drill a new hole in the scrap steel spring mount to restore tension until I can get (or make) the correct parts.
Here is a link to some photos:
http://www.ourcadguy.com/Images/JD185/
Again, thank you!
#12 ronthomp OFFLINE
ronthomp
  • 3 posts
Posted August 18, 2013 - 11:17 AM
#13 yankeewing OFFLINE
yankeewing
  • 1 posts
Posted January 17, 2015 - 04:53 PM
Hi, I need manual sent if somebody still have in clos by on computer. Having problems releasing clutch on a JD 160 I just picked up.
#14 hdg4400 ONLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted January 18, 2015 - 06:44 PM
yankeewing:
Check your mail for a message with some help on your request.
Harlan
#15 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted January 18, 2015 - 10:10 PM
Brian,
I have sent several JD service manuals to members here by attaching them to a Private Message with no problems on either end.
