Hydro Filter
13 replies to this topic
#1 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted June 19, 2012 - 03:01 PM
im trying to find the filter for the hydro unit in my ford yt16h. the parts list shows its a ET103144 which is about $22. does any one know a number for fram, wix or purolator filetrs? i have checked the web sites for the 3 and no go on the number.
#2 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted June 19, 2012 - 03:03 PM
Thank God you don't have the inline on the older LGT 165's. That sucker kills a $100 bill! I know for a fact!
#3 Kurtee OFFLINE
Kurtee
  • 585 Thanks
  • 467 posts
Posted June 19, 2012 - 03:37 PM
Take a look at this link
http://www.maraindus...144-filter.html
I put this up, then notice they show out of stock, sorry
Edited by Kurtee, June 19, 2012 - 03:39 PM.
  • JDBrian and dogsoldier have said thanks
#4 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted June 19, 2012 - 04:47 PM
thanks Kurtee
ill save the site and also asked to be notified when back in stock
#5 HALFSCALE OFFLINE
HALFSCALE
  • 495 Thanks
  • 529 posts
Posted June 21, 2012 - 02:50 AM
I wonder why Eaton used that filter on the fords ,but in the mtd and masseys they used a spin on head that takes a 4 dollar fram filter, thats available from any parts house. I think I would look into converting over ,if it's a work tractor
Edited by HALFSCALE, June 21, 2012 - 02:53 AM.
#6 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted June 21, 2012 - 03:18 AM
it spins on like a regular oil filter or am i misunderstanding you.
#7 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted June 21, 2012 - 03:36 AM
Most all spin ons for the Jacobsen built tractors will use a Fram P 16 filter. Ok, taking this further I have found it to cross to a 86546617 or a wick 51068 or what ever fits a Chrysler engine in the 70's :) not positive, but pretty close I think :)
Hold on now, if you rig takes the ET103144 it is a YT NOT REPEAT NOT an LGT.
Edited by skyrydr2, June 25, 2012 - 03:02 AM.
#8 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted June 21, 2012 - 03:52 AM
thanks skyrydr
ill try that filter and hope for the best. whats the worst that can happen? besides it blowing apart and killing the grass
#9 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted June 21, 2012 - 04:05 AM
It wont fit if yours is the ET103144 , that is the only filter that will fit.
#10 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted June 21, 2012 - 04:21 AM
figures
thanks, wonder if there is a way to convert it for another filter.
with my luck with this tractor probably not
#11 Jacobsen 1600p OFFLINE
Jacobsen 1600p
  • 1 posts
Posted June 25, 2012 - 01:56 AM
I'm looking for a hydro filter for my jacobsen 1600p -1977
Will my fit Fram P 16 filter?? Anyone how know
#12 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted June 25, 2012 - 03:05 AM
As long as it is a spin on and has an Eaton 11 hydro.
  • Jacobsen 1600p said thank you
#13 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted June 25, 2012 - 06:20 AM
Eaton recommends a 10 micron filter that is to be supplied by the manufacture of the machine it is installed in. That is what the ET103144 is rated at. A PH16 is an automotive oil filter and has a larger 21 micron rating.
I did some checking and Fleetguard has MicroGlass filter.
The HF 6446 has the same dimension with a 10 micron rating while maintaining the the 7-9 GPM flow rate.
John Deere uses it on there 2243 Greens mower
The Wix # crosses to 57102.
Will do a much better job IMHO.
  • MH81 and dogsoldier have said thanks
#14 dogsoldier OFFLINE
dogsoldier
  • 361 Thanks
  • 509 posts
Posted June 25, 2012 - 07:47 PM
thanks ducky
i took the fleetguard number and went to fram and the also have a filter , #PH2844
not sure what the micron rating is tho. wjere did you go to find the micron rating?
next time im at walmart ill look and see if they have a 57102
thanks again
