Jd 140h3 Hydraulic Flow Rate
5 replies to this topic
#1 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted June 18, 2012 - 08:48 PM
Does anyone know the gallons per minute flow rate on a John Deere 140H3?
Looking at possibly making a small 3 point log splitter but don't know if there is enough flow/pressure to make it worth while.
Thanks,
Bill
#2 olcowhand ONLINE
  • 41,280 Thanks
  • 31,452 posts
Posted June 18, 2012 - 09:22 PM
Not enough of either Bill. Flow is like 2 1/2gpm tops, and pressure is around 750 to 850psi.
  • GTTinkerer said thank you
#3 hdg4400 ONLINE
hdg4400
  • 284 Thanks
  • 348 posts
Posted June 18, 2012 - 09:47 PM
I have the "Service Manual for the 140 (Serial No. 30,001 - ). I didn't find anything about gallons per minute flow rate, but I did find this info about how it works and the oil pressure it maintains.
Attached File  JD 140 HydroSys PrinOfOp.PDF   118.3KB   158 downloads
Harlan
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 19, 2012 - 03:54 AM
The sundstrand 15 manual may give the exact figures. I think you would need to run a pump off the PTO to get enough flow to run a log splitter. That can be done and it works well.
#5 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted June 19, 2012 - 06:37 AM
The guys are correct- to bust only 20 ton at 500 psi working pressure, you would need a cylinder with a 10 Inch piston. Also, if you need a stroke of, say 24 inches, that cylinder would contain 3.46 gallons, so at 2 1/2 gpm, it would take 1 minute, 20 seconds to stroke it. :orangecool:
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted June 19, 2012 - 04:12 PM
Thanks for the replies. I thought it was a long shot. I'll save the parts and plans for the Copar Panzer project
Bill
