Weekend find
12 replies to this topic
#1 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted July 05, 2010 - 06:44 PM
While out driving i stopped at a lawn sale and found this cub sitting out behind the guys garage he was mowing with a new one so I had to ask. he said he thought it had a bad motor but it ran. long story short bought it for 400.00. Got it home runs pretty good he thought motor was bad because it smoked ALOT. well i checked oil it was halfway up dipstick. so i changed it it runs no smoke but will only run with choke on. any ideas why??:confuse: Im not too good with carb work
#2 Bolens 1000 OFFLINE
  • 15,291 Thanks
  • 18,235 posts
Posted July 05, 2010 - 06:53 PM
Wow good Buy!
If its running on choke it means it's not getting enough gas... Check your fuel line and see if its comming out full stream. There may be something blocking the line.
Or your main jet may need an adjustment. Try turning your main jet counter clock wise about 1/2 to 1 full turn (which will allow more gas to enter) and see if that helps at all
#3 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted July 05, 2010 - 06:55 PM
thanks ill try that out and see if it works. hoping this cub will save some wear and tear on the bolens:smile1:
Wow good Buy!
#4 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted July 05, 2010 - 07:23 PM
Great buy. Just like Brian said, check the fuel line and filter, either the needles are adjusted too lean or they could be clogged or there could be an intake leak. Could also be a float adjustment but usually a float set too low would still make the motor run lean or it won't rev past a certain rpm.
#5 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted July 05, 2010 - 07:33 PM
That looks like a pretty nice find for $400.00!
#6 olcowhand OFFLINE
  • 42,433 Thanks
  • 31,812 posts
Posted July 05, 2010 - 08:07 PM
Likely a lot of carb issues. The overfull block was likely the oil diluted with gasoline either due to a faulty needle valve & flooding the block, or if it has a vacuum fuel pump, the pump's diaphram may have a hole in it & the vacuum pulling fuel into the crankcase. Once it gave problems, he then parked it & everything has gummed up, causing lean mixture. I recommend pulling the carb apart & giving it a good cleaning. Make sure float is ok, and replace the float needle.
Can't make it out...what model is it?
#7 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted July 05, 2010 - 08:11 PM
its a 1641 if my memory is working tonight. i pretty sure the oil was his fault he said he it was low before it started smoking he showed me where low was on dipstick about halfway between hash marks.
and so he added 2 quarts.
#8 olcowhand OFFLINE
  • 42,433 Thanks
  • 31,812 posts
Posted July 05, 2010 - 08:49 PM
2 quarts!!!!!! Dang, that might just make it smoke huh!:bigrofl:
Still sounds like carb needs a good cleaning, but not a bad deal at all!
#9 DGS345 OFFLINE
DGS345
  • 17 Thanks
  • 348 posts
Posted July 05, 2010 - 09:54 PM
yea ill mess with the carb a little tomorrow and let you guys know how i make out thanks
#10 mjodrey OFFLINE
Posted July 06, 2010 - 04:38 AM
Nice purchase .:thumbs:
#11 181 01 OFFLINE
181 01
  • 1 Thanks
  • 16 posts
Posted July 10, 2010 - 04:09 PM
Had the same problem on a old brigs the other day. Backed out the main jet and then set at 1 1/2 turns and it ran great. Might just be a little dirt that is obstructing the fuel flow.
#12 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted July 16, 2010 - 05:15 AM
Did you work on the Cub yet DG? How did you make out?
#13 4mer farm kid OFFLINE
4mer farm kid
  • 1 Thanks
  • 13 posts
Posted July 27, 2010 - 04:37 PM
Nice find on that cyclops! That's supposed to be a nice machine.
