Painting My Trailer
#16
ONLINE
Posted June 15, 2012 - 07:02 PM
#17
OFFLINE
Posted June 15, 2012 - 07:05 PM
Ryan, just checking....you do have negative to the rim... right? I even have trouble remembering, so I wanted to ask.
Yes I have negative to the wheels. I remember by, I want to remove stuff from the wheels. Remove is like subtract, and the negative is the little minus sign.
#18
ONLINE
Posted June 15, 2012 - 07:15 PM
Ah...remembering by association....I do that often myself! It works, and thanks, now I will remember!
#19
OFFLINE
Posted June 15, 2012 - 08:02 PM
#20
OFFLINE
Posted June 15, 2012 - 08:42 PM
Brian, I have only done one cleaning before so I don't know how long it would take on average. And that one time I had to much stuff being cleaned, not enough anode and a weak mixture. I have to get a bunch of rear to make a better tank with more annode surface area.
#21
ONLINE
Posted June 16, 2012 - 06:31 AM
- Toolpartzman said thank you
#22
OFFLINE
Posted June 17, 2012 - 07:18 PM
Something I have done is use a scrap piece of steel and swap the leads to help clear the anodes. Seems to help after several uses.
That's not a bad idea! I will do that once they get to the point were it needs to be done.
#23
OFFLINE
Posted June 17, 2012 - 07:23 PM
I just took the wheels out of the e-tank and wire brushed them off. They are not perfect but they are going on a work trailer. Besides, the tires and wheels are covered in mud and dirt most of the time anyway.
#24
ONLINE
Posted June 17, 2012 - 07:48 PM
#25
OFFLINE
Posted June 17, 2012 - 07:57 PM
Rims are kind of hard to reach all areas in an e-tank anyway. Most things I pull out of the tank I will dry with compressed air & put straight into my blast cabinet for final cleanup. Easier than wire brush, plus gets the stubborn stuff off that the e-tank missed. Then I just leave it in the cabinet till I have time to primer. It will stay in the cabinet for days without rust flashing.
I have noticed! LOL! I wish I had a blast cabinet, or even a portable blaster would be handy.
#26
OFFLINE
Posted June 17, 2012 - 08:56 PM
Matt
#27
OFFLINE
Posted June 19, 2012 - 02:28 PM
Ryan, I picked up a small sand blaster at Harbor Frieght a couple months ago for $40. and it works great. Used it to sand blast my sons Bantam.
They do make a big mess though, you end up with sand every where, including the places the sun don't shine!
Kind of uncomfortable!
Matt
I have looked at HF before. I think I know what one you are talking about. I just haven't committed to getting it yet. I guess I haven't needed it very bad. LOL!
#28
OFFLINE
Posted June 19, 2012 - 02:33 PM
I also finished painting the wheels, not perfect but they are better then they were.
Once I get valves I can mount the tires up and put them back onto the trailer! I can't wait for this to be finished, jobs are starting to line up, for when it gets back in service!
- KennyP said thank you
#29
OFFLINE
Posted June 19, 2012 - 02:43 PM
#30
OFFLINE
Posted June 19, 2012 - 04:19 PM
Matt
