welding
A Welding Question
16 replies to this topic
#1 ncb OFFLINE
ncb
  • 52 Thanks
  • 215 posts
Posted June 14, 2012 - 12:06 AM
I have flux cored wire in my mig for grab and go conveniance but i picked up the non cored standard mild steel wire by mistake and all i had was argon for doing aluminum, being the non proffesional backyarder i am i gave it a shot with what i had on hand. after backing the wire speed off twice because the wire stubbed the work, i ran what was probably the best weld of my life,had that perfect even sizzle you want to here with a mig. I thought the basic idea with a mig weld was to keep oxygen off during the weld .any of the normal welding gasses{argon,nitrogen,helium,co2} should perform that task.So the question is why are there so many fancy welding mixes and what do they do other than remove more money from my pocket . The wrong gas seemed to do the job perfectly.
#2 KennyP ONLINE
  • 41,514 Thanks
  • 47,425 posts
Posted June 14, 2012 - 04:37 AM
I use the 75/25 mix and it does a good job. Just have to watch wind when welding outside. It can blow the gas away while you are welding.
  • ncb said thank you
#3 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted June 14, 2012 - 05:08 AM
Argon is an inert gas and will shield the arc. I'm not sure why they blend it but it could have something to do with cost as well as welding factors.
#4 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted June 14, 2012 - 07:16 AM
Pure argon is perfectly fine, you will get better penatration, and a purer weld .and it will also raise the tensil of most wire as much as 30% .;)
  • KennyP and ncb have said thanks
#5 Cvans ONLINE
  • 7,481 Thanks
  • 6,475 posts
Posted June 14, 2012 - 10:31 AM
From past experience different gases react differently to different metals. We were once doing a project (Hot rolled steel) and could not get the porosities out of the welds with the gas we were using. Went to a tri-mix and the problem was solved. Some of these metals coming out of foreign countries is real junk of which this was some. The weld can look good on the surface and like sponge in the middle. A different gas can make a real difference in a few cases.
  • IamSherwood said thank you
#6 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted June 14, 2012 - 12:45 PM
Argon is exactly what you need for Aluminum. I say you stumbled right into the right thing for the job.
#7 olcowhand ONLINE
  • 43,180 Thanks
  • 32,014 posts
Posted June 14, 2012 - 04:25 PM
But he was welding steel. Pure Argon is fine for steel....just on the expensive side.
#8 ncb OFFLINE
ncb
  • 52 Thanks
  • 215 posts
Posted June 14, 2012 - 06:37 PM
well that worked out okay as well because i used to work for union carbide and had one of my old work buds drop the tank off for free. if i was to have 1 gas on hand for doing everthing what 1 would i pick.
#9 olcowhand ONLINE
  • 43,180 Thanks
  • 32,014 posts
Posted June 14, 2012 - 07:20 PM
If cost weren't that important, or no issue at all, I'd go Argon. But wait for a pro welder to chime in.
#10 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted June 14, 2012 - 09:25 PM
Yep. I see what you mean. Read it wrong.
#11 MH81 OFFLINE
  • 29,979 Thanks
Posted June 24, 2012 - 11:49 AM
The local gas guy has advised using tri mix so you don't have to change tanks to weld different stuff. He says it's as close to a universal gas as he's found.
#12 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted June 24, 2012 - 02:26 PM
Great welding info site
http://www.weldingtipsandtricks.com
Probably more info than any of us will ever need.
Edited by coldone, June 24, 2012 - 02:26 PM.
  • caseguy and ncb have said thanks
#13 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted June 24, 2012 - 02:48 PM
Coldone, Thanks for the link. There is a lot of great info there for guys trying to learn or improve their welding techniques. I wled all the time as part of my business and there are things there that I can use.. :thumbs:
#14 olcowhand ONLINE
  • 43,180 Thanks
  • 32,014 posts
Posted June 24, 2012 - 03:02 PM
Great site! Going to do a lot of TIG video watching there for sure!
#15 caseguy OFFLINE
  • 1,629 Thanks
Posted June 24, 2012 - 09:36 PM
Thanks for the link Britt! I had an ADD moment and stayed there for 1/2 hour! Great stuff there!
Also tagged with one or more of these keywords: welding
