How Do You Tell If A Gt Is Positive Or Negative Ground?
6 replies to this topic
#1 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted June 13, 2012 - 09:13 PM
Several of my bush hogs are positive ground......so when did they start changing these gt to negative?
How can you tell??
I remember at one point the end of the battery cables had two different size clamps.....to fit the different sizes on the battery posts......guessing to prevent hooking it up wrong......anyway....would be interested to see when this changed.....why it changed.....etc....
Daniel was helping me and I hooked the jumper battery leads to the starter.....it ran clockwise with either positive or negative wire clamped to the A post on the starter......lesson learned for me......I would have thought the rotation would have changed.....
So hooking it up backwards damage anything.....if yes what??
Thanks for any info you can provide.
Edited by sacsr, June 13, 2012 - 09:13 PM.
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted June 13, 2012 - 09:40 PM
I am not sure when and why they stopped + ground. I just remember my boss at a garage I worked at as a kid, put a new wiring harness in a customers Old Ford Truck (had a flat head V8).
He hooked the battery up with - to ground, It wound up literally frying the points. But that was the only damage it did.
I would say if you just jumped the starter you would be fine.
  • sacsr said thank you
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted June 14, 2012 - 03:07 AM
Polarity means nothing to a starter, it will spin the same direction no matter how it is wired. Now the charging system will be different, and you may have to reverse the leads on the amp meter.
  • Alc, sacsr and Toolpartzman have said thanks
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted June 14, 2012 - 05:01 AM
You may not have damaged anything by hooking it up backwards. Solid state (transistorized) ignition modules and regulators could be damaged but many of them are protected by diodes internally. Generally if you connect one backwards and there is no protection it will short out and blow a fuse or smoke and be obviously damaged. All you can do is try it in the correct polarity and see if all is ok.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted June 14, 2012 - 06:13 AM
I know nothing of the mechanics of this, and I've been remiss in not having it explained to me in terms I can understand, but there is a process called polarizing. Generators need this when you reverse hookup or they may not charge or charge at a reduced rate. The mechanic that fixed the last issue I had (when I was probably 16) used a device called a growler to test it and then did something that caused a couple of sparks and sent me on my way with a freshly polarized generator.
I would have suspected funny business except there was no charge for the labor, just a pat on the head and a don't do it again.
Anyone know about this process?
#6 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted June 14, 2012 - 06:37 AM
Well I looked at 3 of my owners manuals for these bush hogs. D4-10 and the HD-12 show the wiring diagram with the negative being the ground....the D4-7 D4-10 combination owners manual has "consult motor manual for proper ground" My T63 manual shows a diagram with a "positive ground".....so it is all over the board.
I know my crusty D4-10 with the Tecumseh and the T63 with the Wisconsin S7D is a positive ground.........so somewhere after these early models it changed.....
Just wish I could figure out (with out any thing burning up) how to distinguish positive ground from negative ground models.... :confuse:
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted June 15, 2012 - 12:07 AM
Alan - I have done the polarizing a generator (at the regulator) and can't recall which two terminals I jumped, just know if you jump the wrong ones you get to buy another regulator lol.
As for the positive versus negative ground, old garden tractor manufacturers are bad about battery cables being color coded... both black LOL.
