A Puzzler For Couragious Thinkers Only
oiling onan oil pressure
20 replies to this topic
#16 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted June 13, 2012 - 07:17 PM
But to answer your original question, YES, one could put on an external pump. The regulating valve is between the pump & the oil gauge pressure port. The way the oil flows through this valve, it would not work as a regulating valve with oil coming the opposite way, so the external pump would have to have a regulator on it.
Thanks Daniel and for those who haven't seen one, shown here is the cast block with onlt an 1/8 plug for a gauge- Daniel was it later or diff. specs?? where a cavity was milled out and top and bottom taps for a block-off plate, then the filter was added-or could be added.(In case somebody thought CLEAN oil was a good idea)P6130315.JPG P6130314.JPG
#17 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted June 13, 2012 - 07:25 PM
What make of engine are we looking at? An exploded view may shed some light on pros & cons.
---The EXPLODED view -? Its EXPLODED ALLright and the shinning light says don't buy/build any engine that the manufacturer wasn't smart enough to put an oil filter in !! :bigrofl: :bigrofl:
#18 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted June 13, 2012 - 07:28 PM
Just wondering is it just " your " engine or all this model engine have low oil pressure ? And how much lower is it then factory spec's ? Al
I never ran it Al. Just brought home and opened it up for a peek-PO says knocking and smoking..
#19 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted June 13, 2012 - 07:29 PM
If all this had come up a month ago, I could have gotten some pics of mine with the filter to go with these.
#20 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted June 13, 2012 - 07:30 PM
My Onan has an oil filter. Never been inside it yet, but I plan to pull the heads before long. I want to see if it is a 16HP or 18HP.
I've been on a fact-finding hunt about these and I think the ONLY way to be sure is pull the heads and measure the stroke.
#21 KennyP ONLINE
  • 40,080 Thanks
  • 46,745 posts
Posted June 13, 2012 - 07:40 PM
That's the same conclusion I have come to, Lee. Hope you get something figured out on yours!
Also tagged with one or more of these keywords: oiling, onan, oil pressure
