Mf-8 Hydra Speed Questions
32 replies to this topic
#16 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted February 03, 2014 - 07:58 PM
There's a plastic cup with a lid under the seat, and I think there are level marks on the cup (tank).
Edited by DH1, February 03, 2014 - 07:58 PM.
#17 MH81 OFFLINE
Posted February 03, 2014 - 08:02 PM
I'm sure CAT is spot on, but just so you have it, here is a link to the service manual for that tractor: http://gardentractor...service-manual/
It has lots of info in it, the tranny is covered starting on page 11.
#18 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted February 03, 2014 - 08:20 PM
DH1 is correct, you will see the mark on the side. .946 liter is the total capacity.
  • DH1 said thank you
#19 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted February 04, 2014 - 10:17 AM
Yes, but the axes will in my view, its own oil..?
Edited by MF garden, February 04, 2014 - 10:19 AM.
#20 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted February 04, 2014 - 11:07 AM
I read and watched that maintenance of the manual and in my view, the oil filler cap is put up whether or ..?
That's 946 liters this is by Finnish almost one liter.
#21 MH81 OFFLINE
Posted February 04, 2014 - 12:25 PM
I believe the rear end uses 90w EP and the tranny uses something different. Best read the manual to be sure.
I read and watched that maintenance of the manual and in my view, the oil filler cap is put up whether or ..?.
Not quite sure what you're asking here.
#22 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted February 04, 2014 - 03:17 PM
I have a bit of difficulty because of the language, and I have to use google translator.
#23 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted February 04, 2014 - 09:55 PM
Taka-akseli pitää 1,3 litraa 90 paino vaihteistoöljyä. Pahoitteluni aikaisemmassa viittauksessa hydrostaattinen vaihteisto, jossa pitää .946 litran. Kyllä, kuppi on lähetystä. Taka-akseli on eri asia. Käsikirja on hyvä kuva sivulla 11 tai 12.
Kiittää te ajaksi sinun kärsivällisyys. Ymmärrämme ne hankaluudet kääntää ohjelmistolla, joka on kirjoittanut amerikkalaiset.  Olivat käsikirjat sinulle apua?
#24 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted February 05, 2014 - 06:04 AM
Thank you so much Cat 385 B response. :D  Yes the manuals for the help and I am here to be joining the already copied them to myself. :thumbs:
 Here on our forums is useless to ask these Tractor when there are not that many are not here. And there's even a separate garden tractor forums. I'm building on that after the hydraulic lift and the mower by the plans. I'm writing here in the machine of platforms Lifting projects, and I may be able to put the address of the page where you see the pictures and report if you have interest in the look ..?
Almost all parts of the building have been found in their own corners.
  • IamSherwood said thank you
#25 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 05, 2014 - 06:36 AM
Please post the link to your tractor site over there.
Lähetä linkki traktorin sivuston tuonne.
#26 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted February 05, 2014 - 10:59 AM
Well there is that one machine in our website and in that story of that on their own MF 8 Lifting the project. I have probably made more attached to the tractor. Long topic to be watched and building things will change somewhat between, but the cold will get them something obvious.
Hydraulic pump there is a car power steering pump.
Something outside of the tractor between the images will be displayed.
Finish this does not exist yet, but you can monitor with the events of that link.
Please comment and feel free to ask, but if you feel like it. :D
Images, at least you can see what and when will always be made. The last pages will start to appear more complete trace.
http://www.konekansa...e-ja-niittokone    :smiley-flag001:
Edited by MF garden, February 05, 2014 - 07:37 PM.
  • IamSherwood and Cat385B have said thanks
#27 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted February 06, 2014 - 06:03 PM
Is there anyone got a broken mf-8 hydra speed transmission even if the plow plowing or pulling the rear plate, or has anyone ever tried the resistance ..?
So manual shows that not to be dragged heavy loads, but whether it really is true that can be broken as a result, or whether only document may give it time for people to buy a bigger tractor .. Were larger mf-10-14 probably more expensive.
In fact, at least try and if you are wearing out so I put some other form of transmission so I can get more done mowing lawns.
#28 MH81 OFFLINE
Posted February 06, 2014 - 07:32 PM
The MF8 was designed to pull light loads and push snow or run a small snowblower as well as mow. They are not rated for pulling a plow or heavy dozer work. The term we use here is they were not rated for ground engaging equipment.
This means they were lighter duty than their 10+ hp siblings and while they might do the work for a short period, eventually they would break under the stress they werent designed for.
#29 IamSherwood OFFLINE
  • 8,391 Thanks
Posted February 06, 2014 - 09:45 PM
You did a very nice job on that hitch.
Thanks for giving us the link.
Edited by IamSherwood, February 07, 2014 - 02:23 AM.
#30 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted February 06, 2014 - 10:36 PM
Very nice work on the hitch!
Vaikka MF 8 ei maanmuokkaus työtä, se ei kestä kauan. Maa harjoittaa työ on parasta jättää suuremmat traktorit, kuten MF 16 muun foorumin kuvassa.
