Mf-8 Hydra Speed Questions
32 replies to this topic
#1 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted June 12, 2012 - 02:31 PM
Hi there. Other shareholders would like some information about the whether the MF-8 tractor hydra speed transmission drag loads when the manual says, that does not even get a second tow tractor, or practical experience in sustainability ..?
#2 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted June 12, 2012 - 03:01 PM
Are you asking if the MF8 can pull ground engaging equipment such as a plow?
#3 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted June 12, 2012 - 03:41 PM
Yes, to be built behind the elevators and the small backplate, and perhaps some of the other tillage equipment, which are then pulled behind and think hydra speed transmission durability, and how to take a lot of pull at work ..?
It would also be intended to draw a small garden behind a cart, but how many have the courage to put weight on the trailer ..?
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 12, 2012 - 05:30 PM
Welcome to GTTalk. The MF8 is not rated for ground engaging equipment. It is really a lawn tractor and not a GT. The MF10/12 is a true GT and is rated for ground engaging equipment.
#5 MH81 OFFLINE
Posted June 12, 2012 - 10:01 PM
MF Garden :welcome: to GTTalk.
As said above, the MF 7/8's were not designed to pull ground engaging equipment such as plows, discs, cultivators.
They were considered OK for pulling Medium sized lawn rollers, lawn seeders, lawn trailers, etc. The way I explained it to my son was that if it has it's own wheels, you should be able to use it with a Lawn tractor.
#6 tinner OFFLINE
tinner
  • 503 Thanks
  • 1,561 posts
Posted June 12, 2012 - 10:38 PM
Welcome to GTT MF garden. Hope you find lots of good information here. Enjoy your MF8, they're good riding mowers. I've loaded a garden dump trailer like those you find at Tractor Supply, Sears, Lowes or Home Depot full with rocks and taken them to a washed out area I have and dumped them with my riding mower with no problems. Like MH81 said, if it has it's own wheels you should be able to pull it ok but NO PLOWS or other GROUND ENGAGING EQUIPMENT.
:welcometogttalk: .
#7 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted June 13, 2012 - 06:39 AM
:welcometogttalk: .
But did you have the MF-8 hydra speed when you dragged the heavy loads, when I realized that you've pulled the cart on the big rocks in whether or MF-14 ..?
I get probably give up dreams of lifting the tractor of course, hey, a fine and make it easier to work with the cart, but there was probably not benefit the use of ..?
I am scribbling may lead to confusion when I'm Finnish and I use google translator. Here in Finland do not have a good lawn tractor forums, so I joined here.
Edited by MF garden, June 13, 2012 - 07:00 AM.
#8 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted June 13, 2012 - 07:19 AM
Welcome to GTTalk MF Garden. As stated above not intended for ground engaging equipment.
#9 MH81 OFFLINE
Posted June 13, 2012 - 08:16 AM
MF Garden, I think translate lost a word or two there...
MF10, 12,14,16 plows, disc, drag OK
MF7/8 Not OK
Do you have a picture of what you are trying to pull?
#10 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted June 13, 2012 - 04:36 PM
Thank you for your welcome wishes for :smilewink: . There are no pictures of the tractor project a little still, when I bought it from USA and arrived at Christmas, but the lifting was planning a small outboard plate towed by a snow mostly work, but I think I'll just concentrate on the trailer tow yard doing some gardening.
Perhaps the bigger draw, and I do the transfer work, then the MF-165 tractor and perhaps the future, the MF-135 tractor, the more suitable in a small yard to larger district chores.
Edited by MF garden, June 13, 2012 - 04:40 PM.
#11 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted June 21, 2012 - 04:55 PM
Hello again and this time the question in line is the speed Hydra oil, that kind of oil do you use ..?
#12 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted July 04, 2012 - 01:18 PM
Hello and this time'd designed so that if anyone is put Hydro oil temperature gauge, when I think that'd nice to follow the temperature, when I heard that the hydro-in is steadily warm oils too much and would eventually be a normal oil temperature indicator for the purpose, or should we be even if the hydraulic oil temperature display ..?
Edited by MF garden, July 04, 2012 - 01:18 PM.
#13 MF garden OFFLINE
MF garden
  • 7 Thanks
  • 15 posts
Posted February 03, 2014 - 07:47 PM
Hello again. It would be the kind of question that how much oil to put in a hydrostatic transmission axle at the rear ...?
I need information in liters.
I replaced the axle assembly of shaft seals and now I should put new oil.
#14 MH81 OFFLINE
Posted February 03, 2014 - 07:53 PM
Let me see what manual might have that info.
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
.946 liter
