Start Of A Long T70 Resto-mod
  • This topic is locked This topic is locked
180 replies to this topic
#76 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 09, 2012 - 09:55 PM
Tis a good idea.
The crosley trans on ebay fell through. I was willing to drop 150 shipped but ended up going closer to 165.
Sent from my cell.
#77 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 10, 2012 - 07:41 AM
Yeah, it looks like the going rate for PK tranny is about 250. Crosley is about $150 but then you have to think about getting it sealed up at both ends. You'll be able to do better if you're patient and are willing to rebuild the tranny.
#78 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 10, 2012 - 12:32 PM
Scored the engine i wanted!!
Kohler Magnum 20 in nice condition for $185. Awesome thing was I was driving through Scranton PA for work anyway. Love national craigslist search engines. :)
Sent from my cell.
#79 Canawler OFFLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted July 10, 2012 - 09:41 PM
Sent from my cell.
Just a warning note on the Magnum fuel pumps. My GTX-18 only has 400+ hours on it and the pump has already been a problem. Replacing it on the tractor was impossible because of the engine cowling so I installed an electric pump. Working great so far and cheaper than a stock mechanical one.
When I first started having trouble with the pump I did a good bit of forum searching and read a lot of similar stories.....
Edited by Canawler, July 10, 2012 - 09:41 PM.
  • BowDown said thank you
#80 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 11, 2012 - 06:08 AM
Thanks for the tip.
Sent from my cell.
#81 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 11, 2012 - 04:57 PM
New engine pictures! Needed help unloading it... but wow i can't wait to mock it up. :)
Sent from my cell.
#82 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 11, 2012 - 04:58 PM
Thinking the driveshaft will run under the oil filter side. :) Fixed position no swing like stock.
Sent from my cell.
#83 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 11, 2012 - 06:24 PM
Wow, great deal!
Yeah with the opposed twins... it sure cuts down on height, but now you got to deal with the reduced clearance on each side. You're right about the driveshaft on the one side. On the other side, you got to watch for where your footrest will be. Good luck!
#84 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 11, 2012 - 08:15 PM
Cookie.. If ya don't mind me asking. What kind of shaft is on the input/output of that power king?
#85 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 11, 2012 - 10:52 PM
Sure.
The input has a 7/8 OD spline shaft. It's not an ANSI standard spline from what I can tell, and I spent a little time looking for stuff that fit, but just getting the inside hub from a PK or Crosley clutch disc gets you the perfect fit to it. That is, if you're willing to spend the time to fit it up to whatever you're using to drive it.
The output has a 3/4 OD spline shaft. I spent more time on this b/c it didn't have such an obvious choice to fit my needs. The manufacturer does have a 3/4 standard keyed shaft, but you're going to spend like $125 to get it. On the PK, it fits into a coupler, but I wanted to run the sprocket right off the output shaft. So what I ended up doing was welded a couple of the splines shut, leaving one in between that I carefully cut down into a keyway. Now I can just put a 3/4 ID sprocket on with the key. I was going to take a couple of pictures before I put it all back together - maybe tomorrow night. Hope that helps and doesn't confuse.
Edited by cookiemonster, July 11, 2012 - 10:53 PM.
#86 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 12, 2012 - 05:43 AM
No i believe that works. I have seen a couple trannys on ebay that already have the sprocket and pulley installed. Hmm. I'm not sure if i will run directly off the output or have a short shaft or coupler. Depends on how things fall.
Sent from my cell.
#87 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 13, 2012 - 11:22 AM
Still planning but could use some part sourcing help here...
Thinking a T-Bar style shifter end.. and a T-Handle clutch lever. Something like you would pull up towards the shifter knob (bar).
Anyone know of an off the shelf T-Handle w/cable that's beefy enough to actuate a tensioner for a V-Belt?
#88 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted July 13, 2012 - 01:48 PM
What if you just use any t-bar and then use some 3/8 steel rod bent in the shape of an L as your clutch lever. You could weld a couple of loops onto the shift rod and the L would slide through them. Use a washer or cotter pin as a stop on either end.
#89 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 13, 2012 - 01:59 PM
Tis a possibility. I guess it would better match the original era the tractor was made. LOL.
#90 BowDown OFFLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted July 14, 2012 - 09:37 PM
Prbly next weekend is the next time I will get to work on this. :(
Plan to remove engine and drivetrain.
Posted from my Samsung Galaxy III S via tapatalk 2.
