Was given a new 4.5" angle grinder, discs, and a nice shipment of pulleys, bearings, sprockets from surplus center! Now I just need time to get to work.
Start Of A Long T70 Resto-mod
#166
OFFLINE
Posted December 28, 2012 - 02:06 PM
#167
OFFLINE
Posted January 02, 2013 - 02:16 PM
No more excuses - we need results! ;)
#168
OFFLINE
Posted January 02, 2013 - 02:19 PM
I'll tell my wife I'm getting pressure from the Internet. ;).
#169
OFFLINE
Posted January 02, 2013 - 09:14 PM
Just wondering if it would be easier to put engine
in like the original setup was and adapt pulleys
to run mower deck. I've seen some crazy factory pulley
setups on sears tractors over the years.
#170
OFFLINE
Posted January 03, 2013 - 07:49 AM
Even if I wanted to I don't think I could run the 20HP Magnum in the same location as the stock engine. It's just too much of a beast. Would prbly result in some rollovers on the left side too. LOL.
Part of the charm in redoing the drivetrain completely is going to be using the T-92 3-speed tranny in place of the stock pulley setup.
#171
OFFLINE
Posted January 03, 2013 - 12:12 PM
Ah, I forgot about the transmission.
#172
OFFLINE
Posted January 15, 2013 - 08:00 AM
Well not to add more work to an already non-existent timeline.. but I have made the decision that I will be stretching the front end of the frame 8". I figure I need to cut off the stock motor plate and weld in a new section anyway... why not incorporate a stretch to make the large motor, transmission, pulleys, and steering system fit easier. Also will give me more space for a gas tank, and battery tray.
#173
OFFLINE
Posted January 19, 2013 - 10:52 AM
Sounds like you're heading for a pulling tractor!
#174
OFFLINE
Posted February 20, 2013 - 02:50 PM
Silly idea brewing in my head.
What if I go balls to the wall custom and change the driveline around 180deg. Meaning I would have the (2) drive tires in the front, engine where the seat would normally be. Then have the driver sit where the engine would normally live. Maybe do a single wheel steer conversion. So essentially it would be a front wheel drive tractor with a single steer tire and turning assist with the independent front brakes?
Main draw to this is the lift being on the front, along with a PTO hookup. That way I could power whatever attachment on the front of the tractor, and have decent weight over the drive wheels? Could still have the mower deck be belly mount though.
#175
OFFLINE
Posted March 13, 2013 - 08:30 PM
That's pretty freaky. How's that coming?
#176
OFFLINE
Posted June 07, 2013 - 07:16 AM
Damn I wish I had more time to work on this project. Just too much going on all around.. LOL.
Now I'm pondering electric conversion.
Would make life easier as far as not having to stretch the frame, redo the steering, and find space for a fuel tank. Not to mention custom exhaust work...
#177
OFFLINE
Posted June 17, 2013 - 09:36 PM
In watching this project and thinking back... I think the point at which panzers get tough to re-power is when you go to twin cylinders. Because the stock drive goes beside one side of the engine... when you go to any twin cylinder arrangement, you run out of space pretty quick. Have you thought about ditching the idea of putting a mower deck on it and putting the driveline in underneath the engine? IT's the only thing I can think of to save yourself some work.
#178
OFFLINE
Posted June 17, 2013 - 10:43 PM
Posted from my Samsung Galaxy S III 32gb via tapatalk 2.
#179
ONLINE
Posted June 18, 2013 - 05:44 AM
Didn't some of the Wisconsion engine have 2 cyl. inline ? Would that make it any easier to repower with ?
#180
OFFLINE
Posted June 25, 2013 - 02:04 PM
Seems like the Wisconsin Engines fetch a crazy buck online. Would be better off grabbing a 2 or 3 cylinder diesel for that price.
