K341 Problems
kohler allis 16hp k341
8 replies to this topic
#1 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted June 11, 2012 - 12:46 PM
i have an allis 916 with kohler k341 an when its warmed up under load it wants to spit and sputter and lose power and sometimes it will stall and other times it will run strong any ideas would be a great help
#2 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted June 11, 2012 - 06:54 PM
My quick guess is that the heat from the engine is affecting the performance of the ignition coil.
#3 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted June 11, 2012 - 07:05 PM
Possibly a loose or faulty condensor?
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 11, 2012 - 07:34 PM
I'll add points to the list to complete the ignition system. I've seen a bad set of points cause some strange problems in my K321.
#5 916 hydro OFFLINE
916 hydro
  • 114 Thanks
  • 139 posts
Posted June 12, 2012 - 06:11 PM
yeah thats kind what i was thinkin got a coil on the way let you know what happens ill probally just tune the whole thing up
#6 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted June 12, 2012 - 08:53 PM
If the ignition parts don't help you might want to check the valve clearances.
  • olcowhand and Alc have said thanks
#7 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted June 13, 2012 - 05:55 AM
Forgot that valves set too tight would cause problems like that when the engine hot , thanks broken2 , Al
#8 olcowhand OFFLINE
  • 41,150 Thanks
  • 31,416 posts
Posted June 13, 2012 - 11:23 AM
Slipped my mind too. Yep, that's happened with me also when getting warm. The valves will be ever so slightly open & drops off the compression.
#9 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted June 16, 2012 - 05:35 PM
Could be there's junk in the carburator if it runs fine sometimes and stalls other times like you said.
Also tagged with one or more of these keywords: kohler, allis, 16hp, k341
