Testing Out The 600 And Now Some Questions
17 replies to this topic
#1 Alc ONLINE
  • 6,318 Thanks
  • 7,157 posts
Posted June 10, 2012 - 11:59 AM
Took the tractor for a little test drive and the seller was honest when he said it smoked !!!! I've had 2 strokes that didn't smoke that bad !! The carb needed a little adjusting still not as good as it should be I think so I added Marvel Mystery Oil to the tank and crankcase too maybe get lucky and just a ring gummed up hey you never know ! Mounted the sickle bar and that seems to work well , , there is a bar missing/broke on the very front , not sure what it was there for goes side to side with the blade a guard maybe ? This model bar is supposed to be for under 5hp tractors does anyone know what the difference is ? The reverser works even though it looks a little hoo hoo-eyed The speed changer works but it looks like it should ride up the pulley further when going for high-speed ,should that reach the top of the pulley ? I'm sure I'll be posting more questions as I play around with it , Al
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,475 Thanks
  • 2,811 posts
Posted June 10, 2012 - 03:18 PM
if i remeber right the differance is the belt, one took a 1/2' wide one and the other a 5/8. Not sure what part your missing need to get a picture of where it goes on the unit to be sure.
#3 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted June 10, 2012 - 05:09 PM
Lauber, shouldn't both belts on the speed changer be 5/8" in Al's case?
Al, I think you will be fine if you can get rid of that smoke.
#4 Alc ONLINE
  • 6,318 Thanks
  • 7,157 posts
Posted June 10, 2012 - 06:22 PM
I adjusted the speed changer and it seems to be better now . Here's a picture of the bar on my other tractor it's abut 1/2" goes from the center of the bar straight up then bends 90' at the top. Bad rings I guess Casey , what would you guess ? Al
#5 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted June 10, 2012 - 07:16 PM
That is the sweeper bar, I took mine off, it had been run loose and the threads were worn out.
#6 Alc ONLINE
  • 6,318 Thanks
  • 7,157 posts
Posted June 10, 2012 - 07:40 PM
Does that "sweeper bar" work along with the "tall grass frame "that I don't have either ? Thanks Al
#7 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted June 10, 2012 - 07:48 PM
Al, the tall grass frame bolts above the sweeper bar. As for your Wisconsin, you may have bad rings. I would call Bob and order some rings for your Wisconsin, he probably has them.
#8 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted June 10, 2012 - 08:30 PM
The sweeper bar just pushes the grass to both sides.
#9 Alc ONLINE
  • 6,318 Thanks
  • 7,157 posts
Posted June 10, 2012 - 09:01 PM
How do you know if the tractor has the " Low Speed Pulley " option ? Thanks , Al
#10 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted June 11, 2012 - 09:37 AM
I believe the low speed bolted to the speed changer on these. Lauber can tell you more.
#11 Alc ONLINE
  • 6,318 Thanks
  • 7,157 posts
Posted June 11, 2012 - 09:18 PM
I was talking with Casey about wheels weights does anyone have a picture of what they look like on a 15" wheel ? Was wondering if they used different ones on the 16" and when mounted on the 15" would sit on the lip area ( the place you would normally see wheel weights on a car ) or where they just a inch smaller , thanks Al
#12 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,475 Thanks
  • 2,811 posts
Posted June 12, 2012 - 12:56 AM
You can use the 15" ones on both wheels, but the 16" one only on 16" wheels.
A low speed pulley setup has a big sheave with a small one attached to the side of it. It both to specail bracket that go around the handel bars. A slow speed setup uses a variable pully like the suburban later used. I beleive the belt for the first one is 1/2" and the later ones where 5/8. Also the low speed outfit dont have a control handel up on the handel bars, the other style does. and yes the tractor in the first picture is using a vari-speed with 5/8 belts.
your missing sweeper bar would have come with the mower unit. The tall grass frame parts were another 917 number and optional.
#13 Alc ONLINE
  • 6,318 Thanks
  • 7,157 posts
Posted June 12, 2012 - 05:47 AM
Thanks Lauber1 , I bet 15" wheel weights are hard to find . If I understand you correctly my tractor has the vari-drive ( I was calling it a "speed changer " ) it wouldn't have come with a " Slow Speed pulley " ? Al
#14 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted June 14, 2012 - 03:24 AM
I know my 560 runs slow enough for me.
#15 MH81 ONLINE
  • 29,919 Thanks
  • 29,740 posts
Posted June 23, 2012 - 12:51 PM
Al, how goes the smoking problem? Did the MMO do any good?
