A Look Inside The Engine On My Troy Bilt Jr.
19 replies to this topic
#16 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted June 10, 2012 - 02:47 PM
Brian do you think it was the gas that was left in it or just from water that caused all the damage ? Al
#17 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 10, 2012 - 07:03 PM
I'm not sure Al but it had to have been water and/or condensation that caused the rust on the welsh plug. The needles were partly eaten away and covered with a grey flakey corrosion. If it was stored in an unheated space then condensation would have been a problem over the years. The gas tank, lines and carb were totally dry so any chemical or water that was in the gas and didn't evaporate would be there as well and could have contributed to the corrosion. The seller said it was not used for about 10yrs. It may have been longer than that as the engine shows little wear. The tank didn't even smell like gas. I hate working on carbs but I hope to get this one working again.
#18 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted June 10, 2012 - 07:56 PM
To bad we don't live closer! I love rebuilding carbs! I have been buying carter and walbro carbs as I find them.
I figured I might as well get the old ones that have high speed adjusters while I can.
If you need help on it, you could always send it to me and I'll rebuild it for you. ( no charge of course) I just figured I'd throw that out as an option.
  • JDBrian said thank you
#19 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 11, 2012 - 09:56 AM
Thanks for the generous offer Chris! I'll give it a go myself first. I don't like working on carbs but have had pretty good luck with them so far. If I run into any trouble with it I'll take you up on the offer.
#20 ra111 OFFLINE
ra111
  • 1 posts
Posted June 19, 2012 - 02:11 PM
I have the parts catalog and operating manual
for the Troy bilt junior tiller in pdfs.
Contact me at ra111@aim.com and I will send them to
you for free.
