I have it about 85% Apart, Once I get everything apart its time for some degreasing/Power washing
Posted June 09, 2012 - 12:28 PM
Posted June 09, 2012 - 01:02 PM
Posted June 09, 2012 - 01:06 PM
I agree that you stand a good chance of breaking the sheave by using a puller.
Is there a double/multiple set screw(s) holding the pulley?
I have found an air hammer with a blunt tip tool is often sucessful at loosening stuck pulleys. ....The force can be directed at the hub of the pulley (not the outer edge)to help loosen things up.
Then, while pulling on the pulley with hand pressure, direct the tool at the end of the shaft, being careful not to mushroom the shaft. ....If the shaft has an internal thread, screw a bolt into the threads, and direct the tool at the head of the bolt.
Posted June 09, 2012 - 02:56 PM
Edited by goodnews, June 09, 2012 - 02:58 PM.
Posted June 09, 2012 - 08:09 PM
Posted June 09, 2012 - 08:20 PM
Posted June 10, 2012 - 12:17 AM
Posted June 12, 2012 - 04:32 PM
Posted June 12, 2012 - 04:34 PM
Congratulations. I am interested in seeing it when it's done.
Posted June 12, 2012 - 04:56 PM
Posted June 13, 2012 - 08:42 AM
Posted June 13, 2012 - 08:52 AM
Looking like a good start. Glad the pulley came off without breaking would have been a pain to find one. Waswoundering if you ever got the decals yet as i did not see them or maybe i missed the post?
Posted June 13, 2012 - 09:21 AM
Edited by bhts, June 13, 2012 - 09:21 AM.
Posted June 13, 2012 - 10:15 AM
Brian i have the
1185035 and the 1705377
Will have to see if maybe the other number were changed to newer numbers and let you know.
