Picked Up The Holy Grail In Bush Hogs Yesterday
98 replies to this topic
#46 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted June 17, 2012 - 10:48 AM
Side by side from the front too please!
#47 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,452 Thanks
  • 3,361 posts
Posted June 17, 2012 - 04:34 PM
Had a hard time taking a picture that reflects the difference.....I think the top shot is probably the best.
Edited by sacsr, June 22, 2012 - 04:40 PM.
#48 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted June 17, 2012 - 04:52 PM
Quite the difference Scott!
#49 johnboggs21 OFFLINE
johnboggs21
  • 18 Thanks
  • 184 posts
Posted June 17, 2012 - 05:24 PM
looks like they just supersized everything lol
#50 IamSherwood OFFLINE
  • 8,390 Thanks
Posted June 17, 2012 - 06:59 PM
Yes, those HD-12s, are a monster. I think it's maybe 30-50% bigger than any other
12hp unit from it's time. And heavy too. I pushed one around a few times, and
then decided, "enough of that". So I got it running.
Congratulations on your score, Sacsr. I can tell by your grin in vids, that you're
enjoying it.
  • sacsr said thank you
#51 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted June 18, 2012 - 12:31 PM
Scott, It's great to see you driving it around already.
#52 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted June 18, 2012 - 02:16 PM
Actually, the early JD140 used the same exact pump/gear system, except the hydro control shaft is on the bottom instead of the top like the JB & HD. But the pumps can be swapped around to work either top or bottom. The 140's diff is the same too, except they have disc brakes, but just take them off & they'll fit the Bush Hog perfectly.
As to Wheel Horse units working, I can't say, as I've not seen many WH models to remember exactly. I do know the WH C120 & GT14 units won't interchange.
Good to know, I think mine is weak because the PO was running gear oil in it,might keep a eye open for a better hydro.
Please post a video when you get a plow on it, kind of wondering if yours plows faster than mine.Mine might be gutless because the old wisconsin is worn out or the hydo unit is holding it back, but it can't even plow half as fast as my brother's Cub 123.
Edited by 48willys, June 18, 2012 - 02:17 PM.
#53 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted June 18, 2012 - 02:19 PM
Please post a video when you get a plow on it, kind of woundering if yours plows faster than mine.Mine might be gutless because the old wisconsin is worn out or the hydo unit is holding it back, but it can't even plow half as fast as my brother's Cub 123.
The hydro & diff can plow fast! Must be a worn hydro or your worn engine, as I have two Bush Hog JBI's with the same hydro, but re-powered with large engines & they pull a 10" plow like it isn't there....full on speed.
#54 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted June 18, 2012 - 02:25 PM
Yea I was thinking of a repower, A friend of mine has a two cyl air cooled diesel that would fit in very nice without cutting up the tractor, he is still working on a full rebuild on it though. Would really like to get it together befor the next SC plow day.
  • JDBrian said thank you
#55 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 18, 2012 - 04:35 PM
If you get that diesel engine we would all like to see pics of the re power. That would be a real monster with diesel power!!
#56 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted June 18, 2012 - 04:56 PM
48W....I forget...which model Bush Hog do you have?
#57 48willys OFFLINE
48willys
  • 171 Thanks
  • 86 posts
Posted June 19, 2012 - 06:38 AM
Mines a HD-12, I'm not really sure what year though.
#58 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,452 Thanks
  • 3,361 posts
Posted June 19, 2012 - 08:18 AM
Another HD-12.....cool deal!
I know we have the registry and maybe that is the best way.....but since the bush hog corporation does not have any records of production numbers etc......we really need to capture all the bush hogs serial numbers and models that we can and try to put some production/sales dates with them if it is available....
With the limited numbers out there.....we are going to need each others help to keep them running!! Good to have another bush hog owner in the mix 48willys!
#59 Titus ONLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted June 19, 2012 - 10:06 AM
48willys, what is your location? Welcome to the board!
#60 york0060 OFFLINE
york0060
  • 309 Thanks
  • 146 posts
Posted June 22, 2012 - 03:39 PM
i noticed in a early post you said your hydro was loud, i also have a HD 12 and its hydro has a loud wine also. I put new fluid and filter in it but it didn't change. Just FYI. Cool bush hog. i didn't relize they were that much bigger. i had never seen them side by side. Cool stuff.
Edited by york0060, June 22, 2012 - 03:40 PM.
