Vote for Tractor of the Month
Soda Blaster
13 replies to this topic
#1 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 08, 2012 - 09:09 AM
Cleaning carburators came up in another section and soda blasting was mentioned.
Here is a link to plans for a home made soda blaster that many of you might find useful.
http://www.aircooled...p/soda_blaster/
  • Bolens 1000, Bud, tractorman604 and 11 others have said thanks
#2 Gtractor ONLINE
Gtractor
    The Tractor Hoarder
  • 7,044 Thanks
  • 4,083 posts
Posted June 08, 2012 - 09:28 AM
Thanks for the link!
Now if I could just get my Solex carbs to work as good as that one looks ~~ :itsok:
#3 JDBrian OFFLINE
  • 9,591 Thanks
Posted June 08, 2012 - 10:00 AM
Thanks for the link. I first heard of this technique recently from a friend who restores classic cars. forgot about it until it came up in the carb cleaning thread.
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 08, 2012 - 10:16 AM
The thing I liked about this that many of us already have most of the parts required already in the shop.
I also mentoned using pinesol and water in that carb cleaning thread. I don't think I'll ever use anything else as a carb cleaner. It worked that well.
Edited by JD DANNELS, June 08, 2012 - 10:18 AM.
  • tinner said thank you
#5 Cvans OFFLINE
  • 4,765 Thanks
  • 5,206 posts
Posted June 08, 2012 - 12:24 PM
I like cheap and effective. Thanks for the link to a neat idea! :thumbs:
#6 dogsoldier OFFLINE
dogsoldier
  • 331 Thanks
  • 505 posts
Posted June 08, 2012 - 02:28 PM
how much pinesol to water and how do you use it?
im always looking for other ways to clean stuff
thanks for the link to the soda blaster. im gonna build one :thumbs:
Edited by dogsoldier, June 08, 2012 - 02:29 PM.
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 08, 2012 - 04:08 PM
I think I poured about 1/2 bottle in a dish pan and filled it with warm water. No exact measurements?
The pine oil seemed to lube things in the process. Once left over night everything was clean. Blew everything out with the compressor and re-assembled.
  • tinner, Texas Deere and Horse, JDBrian and 1 other said thanks
#8 JDBrian OFFLINE
  • 9,591 Thanks
Posted June 08, 2012 - 07:17 PM
That's another very useful tip. I have a carb to clean soon. It's off a 3.5hp tec. and has been not been run for about 10years and was sitting with the air cleaner off. I expect it will be a real mess. I'll try the Pinesol and see how it works!
#9 HDWildBill ONLINE
  • 8,841 Thanks
  • 8,615 posts
Posted June 08, 2012 - 07:23 PM
I tried pinesol a while back and the carb ended up with a lot of scale that was a real pain to get off. I'm really interested in the baking soda thing.
#10 caseguy OFFLINE
Posted June 08, 2012 - 09:55 PM
As a matter of fact, I've used this exact set up for other applications before and never even thought about using it to do soda blasting! Thanks for the link I will definitely use this tip at some point!!
#11 KennyP ONLINE
  • 29,609 Thanks
  • 40,561 posts
Posted June 09, 2012 - 12:07 AM
I'll give this a try. And the pinesol! Thanks for the info!
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted June 09, 2012 - 11:04 PM
Yeah that simple siphon would work for a lot of things. It's the same principle used in cup paint sprayguns.
#13 HDWildBill ONLINE
  • 8,841 Thanks
  • 8,615 posts
Posted June 10, 2012 - 09:41 AM
I took a copy of the instructions over to my buddy, yesterday, and he is very interested in giving this a try. If this works like I think it will I can have a carb off, cleaned, and back on with in an hour or two instead of having to let it soak over night.
#14 KC9KAS OFFLINE
KC9KAS
  • 4,904 Thanks
  • 4,362 posts
Posted June 10, 2012 - 07:41 PM
I work for Jasper Engines & Transmissions, and we use Soda Blasters, & Plastic media blasters. Both do a good job on aluminum parts and is much less abrasive as compared to slag/steel shot, and it is environmentally safe.
