Snowblower Engines- Can They Be Used On Gt's?
7 replies to this topic
#1 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 07, 2012 - 09:37 AM
Hi guys
I have an MF8 I am rebuilding and I took a close look at the engine the other night and the cylinder is in pretty bad shape. It's a HM 80 and there are a lot of flat head Tec. 8 and 10 hp engines around. If you add an air filter to those engines can they be used as a replacement engine? Are there any other differences to be dealt with?
#2 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted June 07, 2012 - 09:50 AM
I don't see why not if the specs are the same. Some snowblower engines actually have two crankshafts so they might not all work.
#3 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted June 07, 2012 - 09:52 AM
Internally, there was no difference between a snowblower engine and a standard B&S or Tecumseh engine of the same model series.
As you mentioned, lack of an aircleaner is the primary difference, but sometimes there was additional sheetmetal configured to direct some heated air to the carb intake. ....Some models also added a primer button of some style, and had a 110volt starter instead of 12 volt.
A short-block for any HM80 could be used, provided the crankshaft length & diameter is the same.
#4 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,915 Thanks
  • 2,451 posts
Posted June 07, 2012 - 09:59 AM
I'm not picking on you, Ryan, but your terminology is incorrect. .....While there may be two shafts coming out of the back of an engine, there is only one crankshaft in any gasoline or diesel engine.
The other shaft which you may have seen coming out the back is actually an extension of the camshaft on B&S or Tecumseh engines, and turns at one-half the speed of the crankshaft.
B&S and Tecumseh also made engines with a PTO shaft which came out the side of the engines.
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 07, 2012 - 10:06 AM
Funny this would come up. I just picked up a Troy Bilt Junior with a 3.5HP Tec. with the camshaft used for the reverse drive. It also turns in the opposite direction which gives a 1/2 speed reverse gear for the tiller.
So it sounds like I could use a HM80 or 100 based SB engine to replace the engine in my MF8. I could replace the tin and air cleaner assembly. The other snag is the alternator coil/flywheel. The mf 8 engine has a large coil that mounts under the flywheel. This may not be compatible with the ignition system/flywheel on a newer engine.
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted June 07, 2012 - 11:13 AM
Brian,
Most of the Tecumseh engines I have seen already have the bosses to mount the stator even if not equipped with one and the flywheels will usually be "mountable" too.
Bill
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 07, 2012 - 05:12 PM
Thanks Bill. I'm now looking for 2 engines a K321 and an HM80/100. I'm not having much luck with my GT projects lately.
#8 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted June 07, 2012 - 08:15 PM
I am sure you will find what you need Brian. Be patient and what you need will show up.
Geno
