Clockwise Or Counter Clockwise?
6 replies to this topic
#1 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted June 07, 2012 - 07:03 AM
I have a '94 Kgro with a 18 HP Briggs & Stratton engine, I need to take it apart to replace a broken rod. The bolt that holds the pully's on the shaft is that clockwise or counter clockwise to loosen?
#2 MH81 OFFLINE
Posted June 07, 2012 - 07:14 AM
I don't think I've ever seen one with the LH threads, but that doesn't mean they don't exist. I usually work with the smaller Briggs.
Hopefully, someone with more experience than I can chime in and be more definitive.
#3 Cvans OFFLINE
  • 6,453 Thanks
  • 6,051 posts
Posted June 07, 2012 - 07:54 AM
Everyone I have worked on has been standard right hand thread, counter clockwise to unscrew. Use a 1/2" impact gun to loosen.
#4 woopud OFFLINE
woopud
  • 73 Thanks
  • 164 posts
Posted June 07, 2012 - 09:04 AM
Will try that, thanks!
#5 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 07, 2012 - 09:59 AM
Most left hand thread nuts/bolts are marked with a notch on the corners of the nut/bolt head. It's not always the case but can be a good clue that you are dealing with LH fasteners.
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,162 Thanks
  • 1,331 posts
Posted June 07, 2012 - 11:17 AM
Same here and great advice. If you are going to use an air impact to reinstall the nut please make sure you thread it on by hand a couple of turns. Seen many engines where the crank was damaged after being cross threaded.
Bill
#7 Cvans OFFLINE
  • 6,453 Thanks
  • 6,051 posts
Posted June 07, 2012 - 11:44 AM
Bill's advise is well worth listening to. Nothing worse than buggered up threads and no tap to repair them with.
