Emergency Pulley Repair.
mf12
7 replies to this topic
#1 MH81 OFFLINE
Posted June 06, 2012 - 09:05 PM
I took the final piece off the parts MF12 to Complete the acc'y I want to end up putting on the Scrap Massey when I restore it. Bad news was what I found.
Here is the drive pulley. Seems to be something wrong.
I called all over and couldn't find a replacement. Decided I would attempt to repair this one.
The bushing with the keyway made a good alignment & mount candidate and the other side of the pulley is sandwiched up against another (unkeyed) spacer. When it's on there, it's very tight now. It'll do until I can find another or have to make one myself.
The OD is 2 3/4, the bore is 1 1/8, the belt is 3/8"... "Cant get it" and "Odd Sized" were the most common responses
I about wore out the phone trying different Massey Dealers, Parts Places, etc. No luck yet... Like I said, this'll do for now.
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted June 06, 2012 - 09:13 PM
What is that pulley from? Is it a drive pulley from an attachment?
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Hmmm Alan, sounds like you did the best repair possible, put it on backward to make it even better lol.
#4 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted June 06, 2012 - 10:04 PM
Alan i have a few masseys here for parts and also some nos parts.Whats the part number and i will take a look.
#5 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 07, 2012 - 04:06 AM
Alan I know that you can get pulleys from a local source up here that you weld or bolt to an adapter. The adapters have a fixed OD that fits the pulleys and you select the adapter with the ID needed for your driveshaft. There are bolt on pulleys and weld on ones. You should be able to get these at a local driveline supplier if you can't find what you need used. Given the number of these MF tractors out there you should find something.
#6 KennyP OFFLINE
  • 37,420 Thanks
  • 45,461 posts
Posted June 07, 2012 - 04:24 AM
That's a good fix for now. Good luck finding a replacement!
#7 skyrydr2 OFFLINE
  • 3,869 Thanks
  • 3,401 posts
Posted June 07, 2012 - 04:49 AM
The 2.75 od isnt the issue, as i can get them all day long, the 1-1/8 bore though , that is a bit large, so you have it bored and broached is all, easy peasy!
#8 IamSherwood OFFLINE
  • 8,390 Thanks
Posted June 07, 2012 - 06:04 AM
Just wondering, what/why a 3/8" belt? The only 3/8 I've come across, is for starter/gen.
Also tagged with one or more of these keywords: mf12
