Reviving A Dead Battery
38 replies to this topic
#1 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted June 04, 2012 - 09:14 AM
I am not sure if this is the right area to post this so if it is in the wrong location please move. I did a little experimenting with a dead battery yesterday and the results today are well all I can say is wow. I used a Epsom salt and water solution. This battery I could short across the terminals and get not even a trace of spark. I drained the cells down to the plates and topped them back off with my Epsom salt solution and put the battery on a slow charge for 24 hrs. The arrow on the hydrometer didn't even move on the initial check. Barely got a 1.120 reading after being on the charger and now all the cells read between 1.1275 to 1.1285 on the hydrometer. I am pretty stoked to say the least. Do not know how long it will last but if it saves me from buying a battery for a few months I will be happy. Epsom salt $3 a new battery $50
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 04, 2012 - 09:35 AM
Keep us posted on how this works.
#3 JDBrian OFFLINE
  • 9,601 Thanks
Posted June 04, 2012 - 10:33 AM
Interesting info. It seems that that would dilute the acid but may be causing some other reaction that is reversing deterioration in the battery! I second Bills comment on keeping us posted.
#4 MH81 OFFLINE
Posted June 04, 2012 - 11:24 AM
I have had mixed results on this. On the oldest battery I tried it on (about 10 yrs old, not used in 7), it's working great almost a year later. On the newest one that I tried it on, it still wouldn't take more than about 8 volts... ended up as a core for a replacement.
Hope yours hold up well.
#5 grand OFFLINE
grand
  • 1,987 Thanks
  • 1,996 posts
Posted June 04, 2012 - 11:28 AM
Thanks for the tip Kelly. I may be giving that a try. What was the ratio of Epsom salt to water that you used ?
#6 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted June 04, 2012 - 11:35 AM
Grand I used 3 heaping tablespoons per cup of water. The youtube video I watched called for distilled water but I wasn't going to run back into town for a qt of distilled water so I just used well water. That battery spins that tractor motor over with ease.
  • grand, KennyP, Michiganmobileman and 1 other said thanks
#7 KennyP ONLINE
  • 37,378 Thanks
  • 45,444 posts
Posted June 04, 2012 - 02:40 PM
I have one I'm going to try this on. It hold about 3 volts. Maybe I can bring it back for a bit!
#8 Texas Deere and Horse OFFLINE
  • 14,729 Thanks
  • 15,470 posts
Posted June 04, 2012 - 02:53 PM
I do this to every older battery I own. Here is the thread I started back in Feb. 2011 and had several comments on the subject. You might want to read what everyone had to say then.
http://gardentractor...battery-repair/
#9 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 04, 2012 - 03:26 PM
Brian are you still using the batteries that you revived from last year? I just got a tractor in and the guy brought two batteries and said he thought both are dead. I may try this on them and see what happens.
#10 KennyP ONLINE
  • 37,378 Thanks
  • 45,444 posts
Posted June 04, 2012 - 03:33 PM
Brian, I tried this once before. I just drained this battery and it had lots of black looking stuff coming out of it. It's taking a good charge right now on 2 amps!
#11 Texas Deere and Horse OFFLINE
  • 14,729 Thanks
  • 15,470 posts
Posted June 04, 2012 - 03:39 PM
Bil I have 2 of the 4 battery's I did to begin with are up and still running, #3 last about 1 year and the other 1 didn't ever really take a charge. Maybe the 4th one had a mechanical short in it.
Kenny, The black stuff, is that out of the one you did last year? I have seen that in mine and I think it is the by-product of doing this to them.
#12 KennyP ONLINE
  • 37,378 Thanks
  • 45,444 posts
Posted June 04, 2012 - 04:45 PM
Sure is, Brian! But it's taking a charge of sorts. I'll know more tomorrow!
#13 HDWildBill OFFLINE
  • 8,975 Thanks
Posted June 04, 2012 - 08:13 PM
50% isn't bad Brian. If you can make it last another year or so then that is $50 or so you can use for something else.
#14 HALFSCALE ONLINE
HALFSCALE
  • 478 Thanks
  • 520 posts
Posted June 05, 2012 - 02:30 AM
You really should use distilled water, you will get even better results, the different minerals in water will give different results
#15 IamSherwood OFFLINE
  • 8,390 Thanks
Posted June 05, 2012 - 06:10 AM
I just bumped into this thread. I've been trying to revive 2 8D's, by shocking them with 200amps, then draining
them down with a load tester. After letting them cool, trickling them. Not having much luck. These batteries
have been sitting 3 years.
Going to give the Epson salt a try.
