What Are They Worth.
23 replies to this topic
#1 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted June 03, 2012 - 06:52 PM
ImageUploadedByTapatalk1338767228.903769.jpg ImageUploadedByTapatalk1338767274.277871.jpg
Hey fellas. I know nothing about Bush Hog GT's. Found these 2 locally today and trying to buy them.
Right now I have offered the owner $100 for the pair through his neighbor. Currently the neighbor has them. He told me "that probably won't get them bought"
Any help would be appreciated.
One I think is a D4-7? The other no idea???
#2 olcowhand ONLINE
  • 41,177 Thanks
  • 31,427 posts
Posted June 03, 2012 - 07:25 PM
The V4-7 is missing all the pto apparatus, but otherwise looks complete. The other looks to be a D4-10, and the pic doesn't show enough to see if all is there or not. If engines are stuck, I'd offer $125 each. If engines turn freely and transaxles aren't stuck, I think they'd be worth $150 each. Just my opinion, and other opinions may vary a lot.
#3 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,130 posts
Posted June 03, 2012 - 07:54 PM
I don't know what bush hogs sell for but i think at least $100 a piece.
#4 olcowhand ONLINE
  • 41,177 Thanks
  • 31,427 posts
Posted June 03, 2012 - 08:14 PM
Actually, they would be worth at least $100 just as parts donors. You just don't trip over these tractors that often.
#5 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted June 03, 2012 - 08:23 PM
I am with Daniel. One thing that can be a big issue with the D4-10 and D4-7 (I have not looked at the V4 sheets to know about them)...is the cluster gear in the transaxle.....you can take the white floor cover off and unbolt the 4 bolts on the shifter....then pull the gear cover off.....the first thing on top is the gear cluster.....if it is ground up.....you know it could be issue finding a good one to repair it.....that being said if the V4 has the same transaxle.....good chance one has a good cluster gear...... if you push the mower and the rear is 'catching'....then could be a pinion gear/differential gear is damaged.....I have seen this in 2 of mine........not sure if this is easy to replace or not....so far I have had not had to go that route. $125-$150 is a fair price.......I can see the front pto clutch handle so good chance it is there.... if it is that is a plus. Good luck! If you decide to get it....we want more pictures!!
#6 olcowhand ONLINE
  • 41,177 Thanks
  • 31,427 posts
Posted June 03, 2012 - 08:26 PM
Oh, for darned sure, & some good close-ups of every angle!
#7 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted June 03, 2012 - 08:32 PM
Sorry I was typing when the other post were made......I recently paid $125 for a non running T63 that looked pretty rough......ended up having a motor than actually runs, good rear end, bush hog grill emblem, has the front pto clutch, and misc parts I needed for my other T63.....some of the other parts were so rusted out I just threw them away......I would not have paid much if any more for it....but it ended up being a decent deal for the parts I am able to use off of it.....I have bought the same condition Gt of other makes and paid $75 or so dollars.....the bush hogs are going to cost a little more due to them being pretty rare....
#8 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted June 03, 2012 - 08:57 PM
Ok I don't know a thing about Bush Hogs. But after doing some buying and selling of these old lawn tractors, I can tell you just by looking at the "pieces" (tires, rims, frame, engines) there is at least $200 sitting in each of those. That may be a little generous depending on the engines.
#9 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted June 04, 2012 - 12:07 AM
Thanks fellas. Now I at least have an idea where to be.
#10 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted June 05, 2012 - 11:09 AM
After looking at quite a few Bush Hog's, I notice the lettering on this V-4-7 is different than everything I have seen...
Is that anything significant?
#11 olcowhand ONLINE
  • 41,177 Thanks
  • 31,427 posts
Posted June 05, 2012 - 01:52 PM
Just lettering someone has stuck on it. The original stencil lettering has been painted over. It looks like I can see some of the yellow lettering showing through. It's been painted a couple times I'd guess, as I also see some blue showing, and there was no blue paint on any Bush Hog tractor.
#12 olcowhand ONLINE
  • 41,177 Thanks
  • 31,427 posts
Posted June 05, 2012 - 01:54 PM
Look at the pic close...you can see the original trademark symbol "R" between the "Bush' and the "Hog".
#13 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted June 05, 2012 - 01:58 PM
OK, thanks!
#14 RoosterLew OFFLINE
RoosterLew
  • 82 Thanks
  • 139 posts
Posted June 06, 2012 - 12:27 AM
Well looks like I cannot get them bought. Seems the gentleman is attached to them more than I have wallet.
#15 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,467 Thanks
  • 3,369 posts
Posted June 06, 2012 - 05:39 AM
Sorry it did not work out!
