Whazzat Game 6-1-2012...
  • This topic is locked This topic is locked
25 replies to this topic
#16 olcowhand ONLINE
  • 36,180 Thanks
  • 29,972 posts
Posted June 03, 2012 - 02:50 PM
David Bradley (or later Sears) hydraulic lift kit. Looks like the pump slips into the front end of the tractor frame where the mule drive goes.
  • laurarg3 said thank you
#17 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted June 03, 2012 - 05:31 PM
How about a hydraulic kit for a MTD 800 or 900 series tractor.
#18 KennyP ONLINE
  • 29,410 Thanks
  • 40,401 posts
Posted June 03, 2012 - 10:51 PM
Maybe the Hyd. kit for a Bolens 1050?
#19 OldBuzzard ONLINE
OldBuzzard
  • 6,565 Thanks
  • 4,649 posts
Posted June 04, 2012 - 01:05 AM
Definately NOT for a Bolens. The Bolens kit had the control valve in the pump.
#20 KennyP ONLINE
  • 29,410 Thanks
  • 40,401 posts
Posted June 04, 2012 - 06:34 AM
If I am looking at the pics right, it looks like the valve is on the pump with a cable going to the handle.
#21 OldBuzzard ONLINE
OldBuzzard
  • 6,565 Thanks
  • 4,649 posts
Posted June 04, 2012 - 12:21 PM
Could be, but Bolens just used a rod going to the pump. Also the Bolens unit had a plate that was attached to the lift cylinder and mounted on the top of the transmission housing.
Here's a pic of my G10 with the Hydro Lift Attachment which shows the rod quite well. The plate on the lift cylinder is hidden by the seat/fender pan.
#22 KennyP ONLINE
  • 29,410 Thanks
  • 40,401 posts
Posted June 04, 2012 - 01:10 PM
Gotcha, Buzz! Just thought someone might have added a cable and handle to this set up.
#23 MH81 ONLINE
  • 27,983 Thanks
  • 28,939 posts
Posted June 06, 2012 - 08:52 PM
What does Brian win if he stumps us?
#24 bhts OFFLINE
bhts
  • 1,416 Thanks
  • 2,119 posts
Posted June 06, 2012 - 10:59 PM
Add on hydraulic system for the Massey MF10
#25 MH81 ONLINE
  • 27,983 Thanks
  • 28,939 posts
Posted June 08, 2012 - 09:07 AM
Bob Got It!!!! :dancingbanana:
I was starting to wonder...
This is the early "Power Lift" for the Massey 10, 12G, and 12H
  • IamSherwood said thank you
#26 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted June 08, 2012 - 06:38 PM
Well I was close but not close enough.
What was different between this model pump and the 14 pump?
